Using a stepper motor as a motion encoder
I was a little bored yesterday, so I decided to fiddle with some of my "toys". I was playing with a stepper, and decided to see what the output looks like on a scope. Once I got it hooked up, and gave it a small turn, my head started "spinning" with ideas. Has anyone ever used a small stepper as an input device? I'm thinking that I could use a few opamps to clean up the signal, and then let a micro(the Propeller) count the pulses from each winding. With a bit of logic, I think the propeller could easily keep track of the angular position of the stepper.
Anyone have any experience or "input" on this?
Don't have any links on me, but the first result on google for 'Stepper as encoder' is www.4qdtec.com/stpen.html
Regarding the steppers, voltage and current depend on speed. If you turn fast enough you'll get clear signal and might even use it to power the prop. But you can't use it in a seismoscope. Movement is too small and too slow.
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
