Frequency Generator — Parallax Forums
Frequency Generator
CenlasoftCenlasoft Posts: 265
edited 2009-05-06 21:20 in Propeller 1
Hello,
I just bought a Prop demo board and I am starting to learn the basics. I use the BSII and the SXB already. I want to generate various square or sine waves at frequencies less than 2MHz. I looked at some of the objects and view the spin code, but I am new at this. Is there any example that I can use to produce a simple wave?
Cenlasoft
    edited 2009-05-03 20:42
    Read the application note (AN001) on the cog counters.
    Here: www.parallax.com/tabid/442/Default.aspx
  • CenlasoftCenlasoft Posts: 265
    edited 2009-05-03 20:52
    I'll read it and try it out. Looks great.
    Cenlasoft
  • RaymanRayman Posts: 16,461
    edited 2009-05-04 01:27
    I think most of the simple stuff you'll find only makes square waves...
    Here's a real sine wave generator that works up to several kHz:
    http://forums.parallax.com/showthread.php?p=802833
    visit http://www.rayslogic.com
    Hello,
    I read the application note (AN001) on the cog counters. I am new to the prop and I am reading and trying to understanding it. Can someone show me how to produce a square wave of a frequency between 180 and 210 khz. Could I change a value in the constant section to produce that wave form between the range stated (one frequency continuously). I will continue to read about programming the prop. I need this range for an experiment.
    Cenlasoft
