reading tach terminal from MSD ignition or (-) side of a coil
What do I need to do to condition the tach signal (V8 gasoline engine) -- just a standard signal that any off-the-shelf tach can read so I can read it with a BASIC Stamp?
I have a kit with the 2sx
The MSD ignition has a "tach signal" output that mimics the (-) side of a one coil, single-spark ignition system.
Thanks.
Thanks.
make sure you connect the 0v of the stamp to the 0v of the vehicle (connect the negatives) or it wont work correctly.
Then you could use the pulsin command to make a tacho quite easily.
cheers,
Chris, Western Australia
