Qti help
Hello, Im trying to make by own version of the QTI circuit but am having some trouble.· I am using some QRD1113 http://www.fairchildsemi.com/ds/QR/QRD1113.pdf·I see that the QTI sensors use QRD1114 but dont see how to modify my 1113's to behave like the QTI.· I construcyed to circuit and tried testing them with the code but I am not getting a value change at the input pin.· Right now it only gives me a value of 7 and changes to 8 when something is right on top of it (black tape).· I am using a peace of white paper alternating with black electrical tape.· I am trying to use these sensors for a·maze navagating robot but was unable to make them work properly b/c of the florscent lighting in the room.· So now·Im trying to·detect the top of the walls like a QTI.· Any info would be greatly
appreciated.
Robot specs:
BS2
Supper carrier / boe-bot chass
Continuous rotation servos
appreciated.
Robot specs:
BS2
Also you should not double post in these forums. If you hurry to your other post you can delete it before someone posts to it. Use the red X in the upper right corner.
- Stephen
Post Edited (Franklin) : 5/2/2009 8:40:39 PM GMT
