Stepper motors running in parallel discussion
I was wondering if anyone has had success in wiring 4 stepper motors in parallel. Obviously the IC's would need to be able to handle the current.
My concern is - would they turn at the same speed? I think that this would be possible but not a 100 percent. I have an idea that requires 4 stepper motors possible up to 8 in the future that would have to turn at the same speed. Instead of installing 4-8 stepper drivers I thought that running them into one driver would accomplish the same thing. The steppers require very little current. Your thoughts?
The kit I ordered was two controller boards with two drivers each and a good parallel port breakout board. They seemed like good drivers for the price. I think I paid $89 for the kit, but you can buy just the driver boards for about $40 I think after shipping.
I had good luck with them until this week when I burned a couple of chips changing settings on them. I don't think it was a problem with the boards though, and I talked to them and they are going to warranty the chips for me.
The seller was usbflying if that helps.
I was looking at running some steppers in parallel as well, but after discussing it here, we decided it would be better to run a controller on each one.
data sheet >focus.ti.com/lit/ds/symlink/l293d.pdf this has a large enough current rating for the small steppers that I wish to use at 1 amp per channel.
