Differential Quad Encoder input circuit.
OK, I need to read the A B and Z signals from a quadrature encoder. The outputs are Differential, a + and - for each channel. To spare some pins on the prop(My display is hogging a bunch already). I came up with a buffer circuit to convert the quad output to a single ended version(attached). It a very simple circuit and has an important feature,in that if both sides of the signal are not present it will not operate. Now my question is should i use a schimty trigger on the output of the buffer? Or is this sufficient for the prop to read. The signals from the encoder will be any where from 0Hz to 5KHz, possibly higher, but at the current speeds 5KHz is the norm. and will never exceed 20KHz. I'm using 2n3904 and 2N3906 transistor in the circuit and should be plenty fast enough for this application(I think). More or less I'm concerned about slowing down the level transitions.
Note: this was interfaced to this counter IC: http://www.usdigital.com/products/interfaces/ics/lfls7166/
Best of Luck!
-Brian
