EMIC Text to Speech SIP Module
Could someone please explain what the EMIC is capable of?· i.e.; can it speak in foreign languages, or just English?· Also, please post any other bits of info that aren't in the product summary....
Thanks.
3.1415926535897932384626433832795028841971693993751058209749445923078164062
86208998628034825342117067982148086513282306647093844609550582231725359.....
Thanks.
The EMIC translates American English text into phonemes using various rules, then the phonemes into audio. The EMIC also accepts phoneme strings directly for those times when the pronounciation of a word by rule isn't quit what's wanted. Phoneme strings can also be used for pronouncing non-English words although some unusual non-English phonemes may not be included (I'm not sure).
You can feed it text in any language you want, and it will attempt to read it using American English rules of pronunciation. You would find it often necessary to play with phonetic spellings.
It has trouble in my ears with the pallatives, like the letter "n". The number 13 comes out sounding pretty much like the number 30, especially when the channel is noisy, because it cuts short the n. Overall, I would say it does a very decent job, but you do know you are listening to a synthesized voice. It is certainly easy to use.
Tracy Allen
www.emesystems.com
Robert
Thanks.
Parallaxians -- if the male chip is ever available, please offer male Emics again
http://www.toysrus.com/product/index.jsp?productId=3266604
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
