Midi Decoder — Parallax Forums
Midi Decoder
RutRut Posts: 2
edited 2009-05-02 03:01 in Propeller 1
I am going to rebuild a Tangley Calliope. I would like it to play from a SD card. I can build the unit, but I am not a designer. Does anyone have information on this subject? It has 43 notes and I will be using low voltage solenoids to operate the keys. It wold be nice to use a newer propeller chip.
Rut
    edited 2009-04-28 22:40
    What is the voltage rating of the solenoids and (more important) what is the current rating? How many keys can be activated at a time?
    You will need some kind of "high voltage high current" driver, probably just a power transistor, but you'll also need some way to control 43 solenoids using maybe 12 I/O pins ... easy enough to do.
  • James LongJames Long Posts: 1,181
    edited 2009-04-29 00:50
    Rut said...
    Rut
    Rut,
    I'm working on something right now just for what you are wanting.
    If your interested, let me know.
    James L
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    edited 2009-04-29 13:49
    To get started in Propeller MIDI you Use the link below to read about the project that Thomas Dimock dsigned - Computerized Pyrotechnic Firing System . He also worked on a pipe organ project that may offer you some tips.
    "Enter the Propeller! I initially started working with the Propeller chip building a controller for my pipe organ, and designed a MidiIn object as part of that project (subsequently contributed to the object exchange) that could receive a MIDI stream and use I to control the electro-pneumatic valves in the pipe organ. It occurred to me that if I replaced the switches in my existing firing system with relays, that I could use MIDI to create choreographed shows."
    www.parallax.com/tabid/716/Default.aspx
    Pictures for those that have no idea what a "Tangley Calliope" is:
    www.antiquemechanicalrestorations.com/Tangley_Calliope.html
    Aka: CosmicBob
    edited 2009-04-29 14:01
    TANGLEY CALLIOPE RESTORATION PROJECT (The Entire Series)
    www.carousels.com/bblack/calliope.php
    Aka: CosmicBob
  • JonnyMacJonnyMac Posts: 9,851
    edited 2009-04-29 19:46
    I'm presently looking into the TI TPIC6A595 chip; it's like a '595 shift-register with moderate current (350mA each, up to 50v) outputs. I believe there is already a '595 object; this chip may assist in expanding the outputs you need to drive a lot of valves/relays.
    edited 2009-04-29 21:13
    JonnyMac said...
    I'm currently using the PCF8575 I2C chip. It works well, but does create one problem. The outputs are on when the chip is powered up. I'm getting around that by putting a mosfet on the darlington output power line. The mosfet is turned on after the Propeller boots.
    The PCF8575 will allow up to 128 outputs using two I/O. Currently I'm driving the chips at 400K, so we are about 2x faster than the music streams from the SD card.
    James L
    James L
    Partner/Designer
  • Adam WieslerAdam Wiesler Posts: 81
    Rut, I did something like this last year, only with bells.
    I made a custom board to control it and i have the designs posted on my website.
    www.quigleyelectronics.com-a.googlepages.com/home
    just tell me if you want the .pcb files for expresspcb.com
    you can probably modify it for some other chip and SD.
    Have fun, Adam
