Diy hydra?
Is it possible to make a HYDRA system without buying the whole kit?· I would imagine it would be a LOT less expensive, as I already have the Propeller and a lot of the ports...
What do you think?·
3.1415926535897932384626433832795028841971693993751058209749445923078164062
86208998628034825342117067982148086513282306647093844609550582231725359.....
What do you think?·
You could PM Coley for a price on a Hybrid PCB
http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
New ICON coming, gotta wait for the INK to heal, now we have colour!
My intention of this thread was to ask whether or not one can construct a HYDRA out of a custom PCB/Gadget Gangster Boss Board (http://www.gadgetgangster.com/images/stories/boards.pdf) and components and ports of your own...· So, is it possible to do that, or is there a unique component/port or other part required that is otherwise unattainable?· That is all I would like·to know.
Thanks.
configuration. (I did this on my first Propeller board)
Check the link in my sig for something called "The Propeller Cookbook"
I've outlined a breakdown of individual connections in that document for
folks building their own.
OBC
New to the Propeller?
P.S. once again, Vaati, I have given you Hydra advice. Ha Ha Ha!
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
When I first tried the Propeller I hand wired it as a DEMO board and later re-wired it to convert it into a Hydra. I just working on it a little bit each night after the kids went to sleep. Just do it a section at a time and you'll have it done before you know it.
Robert
I am hoping to get the HYDRA book for my birthday... My mom said I might even get a HYDRA if I can clean up my room...
Well, I had better get cleaning--only 5 days till my birthday!
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
I guess today (the 26th) is it. Happy birthday!! I wished a Hydra for you.
Aka: CosmicBob
It goes on and on... All I need to do now is make sure I save *some* for UPENE....
I found the expansion port connector from digikey. Just search for "digikey connector" on the parallax search page and a thread about the connector should be the first result.
Thanks for all of your suggestions.
