Motor performance discrepancies
Hello,
I'm relatively new to robotics and have undertaken to build my first robot. I'm using the BS2, along with the PMWPAL and a home built h-bridge. I've finally reached the point where I'm experimenting with making my robot move around.
I used 2 identical motors and find that at 100% power both of my motor seem to run about the same speed but at lower speeds one motor will run faster than the other (of course this causes the robot to turn).
Is this normal for two identical motors? (perhaps I just have the motors misaligned)
What's the preferred method of resolving the discrepancy?
A lookup table for predefined speeds?
As it happens, I have motor spindle sensors and counters on the PMWPAL I suppose I could attempt to adjust the faster motor on the fly but if it did not adjust quickly I could imagine a fair amount of oscillation in the track.
Mark
Mark
