How can I measure temperatures around 170 C?
I'm will have soon a solar-hot-water-heating-system. And I want to do some "tests" with it. So I'm looking for a way to monitor the temperature at the exit of the 3 panels.
In sumer, the glycol inside the pipes can go up to 160 degrees. So I can't use a regular DS1620 of DS18B20, which measure only up to 127C.
Also, the pannels are on my roof, and the controller is 3 floors below. At about 30 feets from the panels.
I was thinking about using a 1-wire component because of the distance, but maybe also a 3-wire can works if I slow the shift-in shift-out.
So do you have any suggestion regarding the sensor I should us? The cheaper the better since this is not going to last forever.
Also, Mark (ElectricAye) pointed me that I can have so solder issues with a so high temperature. Can I "simply" use another soledring product?
Thanks for your recommandations,
JM
JM
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
http://www.parallax.com/Store/Sensors/TemperatureHumidity/tabid/174/CategoryID/49/List/0/Level/a/ProductID/96/Default.aspx?SortField=ProductName%2cProductName
Features:
Key Specifications:
- Thermocouple Module
- K-Type (Chromel/Alumel) Element Temperature Range: 32 to 1873 °F (0 to 1023 °C)
- J-Type (Iron/Constantan) Element Temperature Range: 32 to 1873 °F (0 to 1023 °C)
- T-Type (Copper/Constantan) Element Temperature Range: 32 to 752 °F (0 to 400 °C)
Dave▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Dave Andreae
Parallax Tech Support·
Thanks for your replies.
The space I have between 2 solar pannels is abour 1 inch, and the wires are 18" long. I can round the wire around the pipe, but will it still be correct like that? Also, since I will have to build 2 other boards for the 2 other wires, can I buy a DS2760 board from parallax without the wires?
JM
Thermocouple to AD595 to LTC1298 to MCU.. The AD595 is a monolithic thermocouple amplifier - giving an output in the 0-5v range. The LT1298 is a dual channel 12bit ADC .
John
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
