programming TEMPERAURE/HUMIDITY sensor
I am using the #28018 sensirion temp/humidity sensor, and I had a
problem with the code from this website
http://www.parallax.com/Portals/0/Downloads/docs/prod/acc/SensirionDocs.
pdf
program does not keep the data, everytime it reads the data, it
deleletes the previous data.
And I want data to be recorded so that I can have TEMPERATURE/HUMIDITY vs TIME
Is there anyway that I can modify the
program and get the data recorded?
Could anyone give any suggestions?
Thank you very much
Thank you very much
http://www.parallax.com/tabid/441/Default.aspx
Kind regards,
Dave
Dave Andreae
Parallax Tech Support·
My problem is that I cannot logging the data.
How can I "write to file" in PBASIC?
It is also bad form to post the same or similar questions in multiple forums.
- Stephen
