Jellyfish Windmill (too good to be true ?) — Parallax Forums
BeanBean Posts: 8,129
edited 2009-05-06 01:24 in General Discussion
I co-worker told me about this wind mill. http://www.clariantechnologies.com/main/page_plugin_wind_power.html
The Jellyfish Wind Appliance is a small 36-inch tall vertical-axis wind turbine (VAWT) with a solid-state controller and a variable-speed induction generator that plugs directly into an existing wall socket and automatically generates power whenever the wind blows. The Jellyfish can be mounted on rooftops, wind towers or even existing street light poles - which are already pre-wired to the grid and have the tower already in place! And, it can generate up to 40 kWh per month in moderate winds enough to light an average home using energy efficient light bulbs. With a target price under $400 the Jellyfish would be an affordable option for many households and developing communities looking to harness wind power for the first time. Working in tandem with the existing power grid, the Jellyfish enables large-scale distributed-generation, delivering power exactly where its needed and reducing the demand for costly transmission infrastructure.
It's sounds too good to be true to me.
What do you guys think ?
P.S. 40KWh per month works out to about 55 watts continous. So if it works it would be well worth the $400.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
    edited 2009-04-27 16:42
    Yes, it's probably too good to be true. Here is an article that tests and compares small wind generators. Sadly, the results are not encouraging.
  • TubularTubular Posts: 4,774
    edited 2009-04-27 19:50
    I was so disappointed to find this thread wasn't about extracting power from jellyfish (somehow)...
    I read an article in ReNew magazine some months ago about 'Guerilla Solar' and plugging small amounts of energy back into the grid via your domestic powerpoint. Love the concept. Part of the challenge was not letting your electricity meter run backwards at the time of being read by the meter reader person. It strikes me that a good solution would be a dirty big incandescent globe and lid switch in the meter box.
    So if you're an electricity meter reader person, be *very suspicious* of well lit meter boxes
    tubular
  • sylvie369sylvie369 Posts: 1,622
    edited 2009-04-28 01:50
    Tubular said...
    I read an article in ReNew magazine some months ago about 'Guerilla Solar'...
    Synchronicity, man:
    http://comics.com/get_fuzzy/?DateAfter=2009-04-20&DateBefore=2009-04-27&Order=d.DateStrip+DESC&PerPage=10&Search=&x=38&y=9&ViewType=Thumb
    640 x 201 - 66K
  • W9GFOW9GFO Posts: 4,010
    edited 2009-04-28 02:03
    Some Dreamer said...
    In the meantime, we would welcome your support in the Google Idea Contest.
    Sign Up to Be Automatically Notified By Google When Voting Opens!
    It is too good to be true, it doesn't exist!
    When they get further along in the design they are going to have to redefine "moderate" winds to "high" winds if they expect a 3 ft tall VAWT to make 40 kwh per month.
    Light an average home on 55 watts? That's what, three energy efficient bulbs?
    Rich H
    edited 2009-04-28 13:35
    tubular don't know about australia but in canada you can get 2 meters. 1 for power they gave you and one for power you gave them. not worth it though unless generating a mega wat because of access fees. better off to go entirely off the grid and put excess power into hydrogen generation.
    I also was disappointed it was not about jelly fish.
    Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
    edited 2009-04-29 11:01
    mctrivia said...
    Hi McTrivia
    I think if you do it officially they give you a fancy electronic meter that records power flow both ways. However this certainly *wasn't* an officially approved technique. In fact it sounds kind of dangerous (perhaps that is part of the appeal).
    Back to the topic at hand, surely there are some standards on how much power these generate in a wind tunnel? I know its a complex jump to what you actually produce on site with squalls etc. I have a 2 meter, 3 blade rotor hooked up to a 200watt dc scooter motor sitting in the garage waiting for telemetry so I can monitor what it generates. It'll be interesting to see the distribution over time. I have no idea what to expect.
    @Silvie thanks for the comic, very funny and so true...
    tubular
    edited 2009-04-29 16:33
    Out in the open, the scale factors of blade length and mounting height overwhelmingly favor large community generators.
    I wonder tho about special situations, where the lay of the land channels wind over a bluff or up a canyon. That also might be the edge of a house facing the prevailing winds or a city canyon. Most big designs are meant for laminar flow out on a level plain. Gradients of wind can be strong and could change the balance of forces on the fore and aft blades. I'm thinking of my brother-in-law's place on Lake Michigan. The wind hits a 100 foot high bluff and jumps. Put your hand over the bluff and you feel it, but back a few feet it is relatively calm. He installed a traditional wind generator on a tower back inland from the bluff back in the 1960s, but, alas, vibration brought it down within a year and the company that made it in those pioneering days was already out of business.
    Tracy Allen
    www.emesystems.com
  • $WMc%$WMc% Posts: 1,884
    edited 2009-05-02 02:31
    While it sounds good
    My computer power supply alone hogs 950watts, This does not include the monitor.
    How can company's make these clams?
    How do You keep a wind mill in sync with the utility?, And not have an expensive battery array and inverter?
    If Free POWER was easy to get , I think one of US would have figured it out by now.
    _________$WMc%_________
    The Truth is out there············································ BoogerWoods, FL. USA
    edited 2009-05-03 01:53
    the mac mini draws 33W only. but that is a side note. There math is way off or just fake all together.
    edited 2009-05-03 13:12
    Don't know about the company clams, but I see enough ludicrously exaggerated claims on TV, billboards, and in newspapers to make me very skeptical. I won't even mention what comes over the internet or via email. My rule is "If it seems a bit too good check very carefully."
  • PhilldapillPhilldapill Posts: 1,283
    edited 2009-05-05 02:54
    That's marketing for you. Distort reality 179.9° to make your product sell. They don't outright lie(usually), and twist it a full 180°, but man they come close sometimes.
    edited 2009-05-05 07:32
    Hm...
    It could probably light my house IF it generates 55W continuously, as that would be 5 x 11W bulbs, and I usually switch off the light in rooms I don't use.
    As for getting 55W continuously out of such a small generator...
    sounds a bit bogus to me.
    And the final; 'plug it into a socket in your grid'...
    The power companies will just love that. Dozens or hundreds of these 'more or less synchronized' generators in their grid...
    I think they use that 'plug it into the grid' to hide for the user exactly how little power it actually generates...
    'It's not our generator that's at fault, it's your increased consumption!'...
    That may also be the reason that the generators doesn't work during a power outage.
    Of course, as people have high-drain utilities(heated bathroom floors, room heaters, fridges, freezers, PS3 or Xbox360... ) connected to the grid, and that these will suck up all the juice unless they're unplugged, anyhow, is another matter entirely.
    Don't visit my new website...
    i still think genetically modified algy to seperate hydrogen from water and a hydrogen fuel cell would be the cheapest way to make power. All we need is the algy and they are working on it.
    http://www.thaindian.com/newsportal/sci-tech/genetically-engineered-algae-can-be-powerhouse-of-hydrogen-fuel_1002227.html
