Time "?" running 100Khz on a waitcnt — Parallax Forums
Zap-oZap-o Posts: 452
edited 2009-04-27 18:59 in Propeller 1
I am hitting my head against the wall trying to calculate the speed of this loop.
I want to run it around 100Khz for an IC. My prop is running at 80Mhz
PUB ShiftIn (Dpin, Cpin, Mode, Bits) : Value | InBit
   dira[noparse][[/noparse] Dpin ]~
   outa[noparse][[/noparse] Cpin ]:=0
   dira[noparse][[/noparse] Cpin ]~~
   InBit~
   Value:=0
  REPEAT Bits
          !outa[noparse][[/noparse] Cpin ]
          InBit:= ina[noparse][[/noparse] Dpin ]
          Value := (Value << 1) + InBit
          [b]waitcnt(1000 + cnt)[/b]
My thinking is that I am running at [noparse][[/noparse] 80Mhz / 1000 = 80khz] = seconds at 12.5uS. Is this right?
So running at 100Khz I thought that I would change to this
[b]waitcnt(800 + cnt)[/b]
Please inform me if I am making a mistake.
  • Brian FairchildBrian Fairchild Posts: 549
    edited 2009-04-27 16:27
    It's unlikely it'll run at that speed. SPIN has a maximum speed of around 100,000 lines per second.
    You could time the critical section with something like this...
    CON     ''General Constants for Propeller Setup
      _CLKMODE = XTAL1 + PLL16X
      _XINFREQ = 5_000_000
    OBJ     ''Setup Object references that make this demo work
    Ser     :       "FullDuplexSerial"
    VAR
    long    ClockStart
    long    ClockStop
    long    ClockDelta
    long    maxtime
    long    interval
    PUB Serial_DEMO
        Ser.start(31, 30, 0, 2400)  ' Initialize serial communication to the PC
        repeat
          ClockStart := cnt
    ***YOUR CODE HERE***
          ClockStop := cnt
          ClockDelta := ClockStop - ClockStart
          ClockDelta *= 125         ' Convert clock ticks to micro seconds
          ClockDelta /= 1000
          ser.tx(1)                 ' Tell me what the value is through the serial port
          ser.dec(ClockDelta)
    Post Edited (Brian Fairchild) : 4/27/2009 4:36:24 PM GMT
  • MagIO2MagIO2 Posts: 2,243
    Hi Brian,
    you forget that both assignments need some time as well.
    Before starting the loop you should do a measurement without any code in between and subtract that from the measurements later on.
    ClockStart:=cnt
    ClockEnd:=cnt
    MeasurementRuntime:=ClockEnd-ClockStart
    @Zap-o:
    Just remove the waitcnt and see how fast it is then.That's closest you can get to 100kHz using SPIN.
    You should remove the InBit. It's an additional assignment which only consumes time.
