Is my servo broken? (w/ Video) EDIT: Won't Respond Anymore. It's probably broke
Hello,
I have here a Parallax Standard Servo, and it only spins bout 90 degrees from the pulsout range of 500 to 1000.
Is this normal?
Here's a link to a video of it: www.youtube.com/watch?v=eua0iwpVJdQ
In the vid, the servo is controlled with a pot resistor, and code taken directly from the "What is a Microcontroller?" Parallax book.
Post Edited (Neodudeman) : 4/27/2009 3:28:16 PM GMT
Is this normal?
' {$STAMP BS2}
' {$PBASIC 2.5}
scaleFactor CON 200 '500(servo minimum) / 640 (pot max) * 256
offset CON 500
rcPin CON 10
delay CON 10
servoPin CON 14
time VAR Word
Do
HIGH rcPin
PAUSE delay
RCTIME rcPin, 1, time
time = time */ scaleFactor
time = time + offset
PULSOUT servoPin, time
DEBUG HOME, DEC5 time
LOOP
Dave
Dave Andreae
Parallax Tech Support·
The thing about that, is, my Debug Terminal is outputting that I am pushing out numbers 500 to 1000
@ Dave
I just tried it, and the servo didn't move. Now, it won't even move with the original program.
I think it's officially broken now, cause it just clicks at me, and doesn't move.
' {$PBASIC 2.5}
scaleFactor CON 50 '500(servo minimum) / 640 (pot max) * 256
offset CON 10
rcPin CON 7
delay CON 6
servoPin CON 14
time VAR Word
DO
· HIGH rcPin
· PAUSE delay
· RCTIME rcPin, 1, time
· time = time */ scaleFactor
· time = time + offset
· PULSOUT servoPin, time
· DEBUG HOME, DEC5 time
LOOP
Dave
Dave Andreae
1) It helps to provide adequate information. You didn't say what Stamp you're using, what power source. Even if you've got dead batteries now, you still might have made an error in typing your program. You didn't mention that you're displaying the values you're using for the PULSOUT statement. The more thorough your information, the better the advice you'll get. It always helps to attach a copy of your source program to your message (don't cut and paste it if possible). Use the Attachment Manager (when you Post Reply).
2) Try fresh batteries. If all else fails, call Parallax Tech Support.
Well, I did quote the source out in [noparse][[/noparse]code] brackets in my first post that included the {$STAMP BS2} tag, and the DEBUG HOME, DEC5 time logic.
I guess you didn't see it? I really was trying to put out all the information I could. I mean, heck, I recorded a video and uploaded it to YouTube to illustrate the problem.
Dave, I did try your code, and the servo simply isn't responding anymore. It won't even respond to my old code. I think it's officially broken now.
Thanks for the help, anyway.
Dave
Dave Andreae
