Project suggestion for bs2 homework board edition
I am interested in any suggestions for a project using the bs2. i have the "what's a microcontroller" text and homework board. any suggestion on a simple project idea that can be completed less than a week?
Well, what it really comes down to is what you want it to do, and what parts you have available.· Could you please explain a bit more in-depth about what you have in mind, if anything in particular?
Thanks.
3.1415926535897932384626433832795028841971693993751058209749445923078164062
86208998628034825342117067982148086513282306647093844609550582231725359.....
thank you again for your help
- Stephen
It depends. What level of programmer (it's mostly a programming problem) are you? Generally, after a semester (or half) I think this would be an acceptable project at the high school level. The general gist of the program isn't that difficult, and it would simply require copying a bunch of code over and over again, and have a DO-LOOP. Any more, and you'll have to figure it out.
Thanks.
thanks to all yall!!!! i will talk more tomorrow.
- Rick
Sorry for the delay. If you want, I will post the schematic, code, ad a video of my super awesome LED flasher either tomorrow or Thursday. I have been working on a contest all week and haven't had too much time to spare. Just to describe the LED flasher, it consists of 6 LEDs: 2 greens on the ends, 2 yellows inbetween the greens, and two red LEDs between the yellows. The program is simple: all the LED's are connected to the I/O pins with a 1k ohm resistor, and the LED's are connected to P0 (green) P2 (yellow) P4 (red) P6 (red) P8 (yellow) and P10 (green)
I will post more info tomorrow.
Thanks.
