Maximum output current from Basic Stamp 2 I/O
Dear all,
What is the maximum output current and voltage from a Basic Stamp 2 I/O pins?
Kindly advise
Kindly advise
Page 67 gives the maximum current "sunk" into any I/O pin (from +5V) or "sourced" out of any I/O pin (to ground). It also gives the maximum range of input voltages that can be applied to any I/O pin. More voltage or more current than this will likely damage the device.
Page 71 gives the minimum output high voltage (Voh) and maximum output low voltage (Vol) for any I/O pin.
Have a nice day!
