simple_serial problem
Hi folks,
I have been trying to use the "simple_serial.spin" code to send data to another processor.
Unfortunately it reacts as if the two devices cannot get synch - or incorrect data is received.
It is set up correctly for N4800 on both chips.
Anyway, I decided to have a look at the pulse train on a CRO and it didn't look quite right.
On closer examination the Start pulse and subsequent data bytes looked OK, but after the stop byte, it reverted to a "non-idle" state, which of course is the state of a start pulse.
This would throw the rx device into some confusion!
I inserted another line of code to force the Tx pin to "idle" state, after the end of the byte.
The following is the relevant code:
That fixed it, and it is now working OK.
I'm surprised that this hasn't been noticed before - the file has been downloaded over 2000 times!
kenmac
Perth, Western Australia
Time Zone = GMT + 8
PUB tx(txByte) | t
{{ Transmit a byte; blocks caller until byte transmitted. }}
if txOkay
outa[noparse][[/noparse]sout] := !inverted ' set idle state
dira[noparse][[/noparse]sout]~~ ' make tx pin an output
txByte := ((txByte | $100) << 2) ^ inverted ' add stop bit, set mode
t := cnt ' sync
repeat 10 ' start + eight data bits + stop
waitcnt(t += bitTime) ' wait bit time
outa[noparse][[/noparse]sout] := (txByte >>= 1) & 1 ' output bit (true mode)
outa[noparse][[/noparse]sout] := !inverted [b] ' ########## code added ##########[/b]
if sout == sin
dira[noparse][[/noparse]sout]~ ' release to pull-up/pull-down
kenmac
Time Zone = GMT + 8
I'm not sure what you mean - are you talking about the last line?
This code is part of the Object Exchange - I only added the one line (marked with#####)
The new line only changes the state of the output pin to "idle".
kenmac
Time Zone = GMT + 8
Post Edited (MagIO2) : 4/26/2009 3:12:22 PM GMT
I would like to make a suggestion though. I think that it would be good to add a "Patch History" section to objects to identify the fixes that are on a particular version of an object. as an example, see the following:
In the object header comments, add:
At the top of the object: '' Patch History: '' '' PatchID Description '' ------------------- ----------------------------------------------------- '' Patch-kenmac-090426 inserted line of code to force Tx pin to "idle" state after the end of the byte.and in the code:
PUB tx(txByte) | t {{ Transmit a byte; blocks caller until byte transmitted. }} if txOkay outa[noparse][[/noparse]sout] := !inverted ' set idle state dira[noparse][[/noparse]sout]~~ ' make tx pin an output txByte := ((txByte | $100) << 2) ^ inverted ' add stop bit, set mode t := cnt ' sync repeat 10 ' start + eight data bits + stop waitcnt(t += bitTime) ' wait bit time outa[noparse][[/noparse]sout] := (txByte >>= 1) & 1 ' output bit (true mode) outa[noparse][[/noparse]sout] := !inverted ' Return to idle state (Patch-kenmac-090426) if sout == sin dira[noparse][[/noparse]sout]~ ' release to pull-up/pull-down outa[noparse][[/noparse]sout] := !inverted [b] ' Return to idle state (Patch-kenmac-090426)[/b] if sout == sin dira[noparse][[/noparse]sout]~ ' release to pull-up/pull-downI think that this would help us keep things straight and know what we are getting when we use a canned object.
I don't understand what was happening in your application (hardware/software) to make you see that issue, but all indications are that the tx method is correct.· I even tested it myself just now on a scope exercising all the possible modes of operation.·
The way the code is written, even without the new line you entered, the output pin is reverted back to the resting state after the last bit of data is transmitted.
Adding the outa[noparse][[/noparse]sout] := !inverted line once again is redundant and has no effect that I can see.
The only thing I can think of that happened to you was that perhaps in your call to init() you were specifying the same pin number for both the rxPin and txPin parameters (initially) and then just happened to set them to different numbers after you made edit to Simple_Serial... if both rxPin and txPin are the same value,·Simple_Serial sets the txPin to input after the stop bit is sent, allowing the line to be pulled-high or low by an external resistor (or float if there is no resistor)... in your case it would seem it needed to be pulled-low·since you're using inverted mode.·
This would cause the strange effects you witnessed if, indeed, you didn't have a pull-down resistor on the line and never intended it to be used that way (ie: you seem to indicate it should always be driven in your application, as is normal).
Any further thoughts or info that I'm missing?
--Jeff Martin
· Sr. Software Engineer
· Parallax, Inc.
Thanks for your reply.
I thought this thread had disappeared from view.
I'm working on other things now, but will see if I can re-create the previous set up .
I was using the code in "tx only" mode, with the RX pin set as -1.
I can't recall whether I had a pull down resistor fitted but I'll try it.
I'll get back to you in a few days.
Ken Mac
Time Zone = GMT + 8
