help with sending bluetooth for color detecting-line following boebot
AUseniordesign
We are in the last week of our senior design project. We have designed a line following boebot that will detect a ball when it pass it, then detect the color using the TSC230-DB, and then will send this information via the eb500 to another robot. Then that robot will navigate not following the lines to pickup the balls and drop them off at the specified spot for it's color.
I am having a problem where the eb500 continually sends info over bluetooth while detecting the color. Here is my code. Can anyone tell me why it is constantly send info? And the info is just garbage...nothing readable.
'Main Program
Main:
OUTPUT TcSLeds ' allow direct control
TcsLeds = IsOn
DO
IF (pos<9)THEN 'stop after 9 balls found
DEBUG ? pos
GOSUB Detect_Line
GOSUB Drive_Motors
GOSUB Detect_Object
IF(rawColor > 20)THEN
PAUSE 500
GOSUB Ave_RGB
GOSUB Match_Color
PAUSE 1000
FOR counter = 1 TO 25
GOSUB Detect_Line
GOSUB Drive_Motors
NEXT
ENDIF
DEBUG DEC rawColor, CR
rawColor = 0
LOW 10
LOW 9
ELSE
GOSUB Ending
ENDIF
LOOP
END
' Subroutines
' Sends wave of frequency "LedFreq" to front LEDs. Reflected
' wave is detected by L
Detect_Line:
FREQOUT LedFreq, FreqTime, FreqRate
l_sensor = LSensor
r_sensor = RSensor
RETURN
' Rotates servomotors based on states of "l_sensor" and "r_sensor"
' Left motor turns if no line is visible on left
' Right motor turns if no line is visible on right
Drive_Motors:
IF ((l_sensor = NoLine)AND(r_sensor = NoLine)) THEN
PULSOUT 13, 850
PULSOUT 12, 697
ELSEIF((l_sensor = NoLine)AND(r_sensor = Line)) THEN
PULSOUT 13, 850
PULSOUT 12, 755
ELSEIF((l_sensor = Line)AND(r_sensor = NoLine)) THEN
PULSOUT 13, 750
PULSOUT 12, 697
ENDIF
RETURN
' Detects object by reading through a single filter for any
' intensity.
Detect_Object:
filter = Red
GOSUB Read_Color
RETURN
' Finds average RGB intensities for sample
Ave_RGB:
FOR counter = 1 TO 100
GOSUB Read_RGB ' color balance sensor
redBal = ((counter-1)*redBal + redVal)/counter
grnBal = ((counter-1)*grnBal + grnVal)/counter
bluBal = ((counter-1)*bluBal + bluVal)/counter
NEXT
RETURN
' Reads RGB values
Read_RGB:
filter = Red
GOSUB Read_Color
redVal = rawColor */ $0148 MAX ScaleMax
filter = Green
GOSUB Read_Color
grnVal = rawColor */ $01EE MAX ScaleMax
filter = Blue
GOSUB Read_Color
bluVal = rawColor */ $010B MAX ScaleMax
RETURN
' Reads selected color from TCS230
' -- takes "filter" as input
' -- returns "rawColor" as output (unscaled color value)
Read_Color:
SELECT filter
CASE Red
HIGH TcsS2
LOW TcsS3
CASE Green
HIGH TcsS2
HIGH TcsS3
CASE Blue
LOW TcsS2
HIGH TcsS3
CASE ELSE ' clear -- no filter
LOW TcsS2
LOW TcsS3
ENDSELECT
COUNT TcsFreq, ScanTime, rawColor ' return unscaled value
RETURN
' Match_Color finds the ratio between Green/Blue intensities and
' then checks to see if the intensities fall within the expected
' tolerance for a color.
Match_Color:
RGRat = (redBal*100)/grnBal 'Finds ratio of red to green
IF(RGRat>300)THEN
colpos(pos)= 1
DEBUG "The color is Magenta.", CR
HIGH 9
LOW 10
ELSE
colpos(pos)= 2
DEBUG "The color is Blue.", CR
HIGH 10
LOW 9
ENDIF
pos=pos+1
DEBUG ? colpos(0),? colpos(1),? colpos(2),? colpos(3),? colpos(4),? colpos(5),? colpos(6),? colpos(7),? colpos(8), CR 'displays each element of the array
RETURN
'Ending is the subroutine that is called after all 9 balls have been found.
'The boe-bot rotates 45 degrees clockwise then goes forward
Ending:
FOR counter = 1 TO 18 'rotate 45 degrees right
PULSOUT 12, 800
PULSOUT 13, 850
NEXT
FOR counter = 1 TO 20 'go forward off track
PULSOUT 12, 697
PULSOUT 13, 850
NEXT
SEROUT 1, 84, [noparse][[/noparse]CR, ? colpos(1),? colpos(2),? colpos(3),? colpos(4),? colpos(5),? colpos(6),? colpos(7),? colpos(8),? colpos(9)]
END
^^^^(serout not correct yet...haven't figured out how to output an array yet.)^^^^^
Post Edited (AUseniordesign) : 4/25/2009 8:54:26 PM GMT
'Main Program
Main:
TcsLeds = IsOn
DO
DEBUG ? pos
GOSUB Detect_Line
GOSUB Drive_Motors
GOSUB Detect_Object
PAUSE 500
GOSUB Ave_RGB
GOSUB Match_Color
PAUSE 1000
GOSUB Detect_Line
GOSUB Drive_Motors
NEXT
ENDIF
rawColor = 0
LOW 10
LOW 9
ELSE
GOSUB Ending
ENDIF
LOOP
END
' Subroutines
Detect_Line:
l_sensor = LSensor
r_sensor = RSensor
RETURN
Drive_Motors:
PULSOUT 13, 850
PULSOUT 12, 697
PULSOUT 13, 850
PULSOUT 12, 755
PULSOUT 13, 750
PULSOUT 12, 697
ENDIF
RETURN
' intensity.
Detect_Object:
filter = Red
GOSUB Read_Color
RETURN
Ave_RGB:
NEXT
RETURN
' Reads RGB values
Read_RGB:
filter = Red
GOSUB Read_Color
filter = Green
GOSUB Read_Color
filter = Blue
GOSUB Read_Color
RETURN
Read_Color:
SELECT filter
CASE Red
HIGH TcsS2
LOW TcsS3
CASE Green
HIGH TcsS2
HIGH TcsS3
CASE Blue
LOW TcsS2
HIGH TcsS3
LOW TcsS2
LOW TcsS3
ENDSELECT
RETURN
Match_Color:
IF(RGRat>300)THEN
colpos(pos)= 1
HIGH 9
LOW 10
ELSE
colpos(pos)= 2
HIGH 10
LOW 9
ENDIF
pos=pos+1
RETURN
Ending:
PULSOUT 12, 800
PULSOUT 13, 850
NEXT
PULSOUT 12, 697
PULSOUT 13, 850
NEXT
END
- Stephen
Also it would help if you used the attachment manager to attach the actual .bs? file you are trying to get help with. What you posted is not a complete program and will not compile.
- Stephen
Post Edited (Franklin) : 4/26/2009 8:17:18 PM GMT
With that - I am suspicious of the END statement in your Ending subroutine.
It is not a good practice anyway to enter subroutine and not use RETUN statement.
Minor suggestion - you should not send serial data without checking if the receiving end is ready to accept it ( hardware handshake).
Post Edited (vaclav_sal) : 4/26/2009 10:35:24 PM GMT
