Having Trouble with PASM TEST Instruction — Parallax Forums
JonnyMacJonnyMac Posts: 9,852
edited 2009-04-25 17:25 in Propeller 1
I'm baffled over something that should be stupidly easy. This works as I expect:
testbit                 mov     tmp1, ina
                        and     tmp1, pinMask           wz
        if_z            wrlong  zero, pinStatus
        if_nz           wrlong  one, pinStatus
                        jmp     #testbit
... but this version doesn't; it always returns 0 even when the pin is high.
testbit                 test    ina, pinMask            wz
                        jmp     #testbit
I must be missing something but, for the life of me, have not been able to deduce what that something is....
    edited 2009-04-25 16:37
    Okay, never mind -- problem solved by switching the order of operators for test
    testbit                 test    pinMask, ina            wz
                            jmp     #testbit
    This version works but as both pinMask and ina are variables I don't understand why the order matters.
    Post Edited (JonnyMac) : 4/25/2009 4:42:46 PM GMT
    edited 2009-04-25 17:16
    "ina" is a special register, only accessed properly when it is in the "source" part of the instruction - when in the "destination" part you access the "shadow" ram "beneath" it.
    JonnyMac said...
                            jmp     #testbit
    www.mikronauts.com - a new blog about microcontrollers
    Thanks for the clarification, Bill. For as much BASIC Stamp experience as I have I should have figured that out.
