Clock on Prop 2
mctrivia
This has probably been answered some where but I could not find it. Will the prop 2 run off the same 5 MHz crystal but with a 32x PLL or is it going to be a 10Mhz crystal with the same 16x PLL? Pretty sure I remember it was going to be internally 160Mhz.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
the biggest question is that what it will be?
I can build a pll with 2,4,8,16x easy enough but more care needs to be taken the higher I go
