Anyone need some CAD designs done?
Hi folks,
I am trying to get my own electronic packaging "shop" going as a side business for a little hobby money.· I have over a decade of experiance in packaging of micro electronic modules, units (black boxes), test fixtures, fabrication fixtures, cables and harnesses for space and commercial applications.· All drawings would be done in SolidWorks.
If you have something I can help you out with please drop me a PM.
Thank you.
Mark.
12-25-07 Got SX Lite Kit Plus for Christmas
12-27-07 Bought LED's and other components
12-29-07 Realized that none of my wal-warts work with board
1-2-08 Bought power supply and turned on·board, but realized the A shell sub-D connector on laptop is actually 15 pins and not serial.
1-3-08 Decided to use old laptop with a serial sub-d, that barely meets the minimum sk-key requirements.· Got LED to BLINK!!!!!!
2008 Went through most available SX/B info and started to read through Gunther's book.
Thank you.
Mark.
all the work I have done ends up as company propriatery, so I don't have anything I can show yet.· I can create a quick drawing of a bracket or something like that to show the detail and quality I put in my products, so let me know what you have in mind.· If you have a quick part you need documented/designed I can get that done too.· Emphasis on quick as this would be a gratis service, the caveat here would be I get to use it as an example in the future.· Let me know.
Mark.
Will this work? I tried to provide as much detail as possible.
sorry for the delay in a reply, it has been a very busy weekend.
This is a good start but what you are really after is a mounting system and not just·a bracket.· This is a bit more involved so it will take a bit more time to get it cranked out.· I am game if you are.· As for the online machinist, I don't have anyone identified, but I do have a local guy in CO that got recomended.· If not, I got an old buddy in LBC that might still have his machine shop in business, so let me know.
I see you pasted some Project Guidelines text.· Can you tell me what this is from?
Now for the details:
I am sure I will have more questions
The project guidelines are my own. I just put them in a quote to make it a little more clear exactly what's in the project. As for the design, I was thinking a w shape would work fine. Make two and connect them by a pair of bars (or four with two cross braces). As a side note, I do have access to a full machine shop (at my university), but I've never used it for any metal projects or milling.
1. There is 1" of clearance from the top of the (green) battery to the bottom of the frame. This is in general across the top of the batteries. For the last 1/2" of battery (aft) there can't be anything. The space already has two screws in it. If needed, you could use the space in front of the yellow battery on the bottom. That is about 9/8" of an inch from the front of the battery.
2. No existing mounts are available. Some holes through the deck would be fine.
3. This is a robotics application. Crashes will probably happen, but you can plan for no contact with the battery mounts. If they were to actually hit something, the vehicle is lost anyway (in pieces!) Therefore, you only need to plan for the forces involved in acceleration.
4. I was thinking of milled metal with tapped holes for the connections. However, I don't really have any particular requirements. Cost? The whole assembly should probably be less than $50 (if that is a reasonable number to pull out of the air.)
5. These are the only batteries that I'll be using. They're pretty much a standard size (with perhaps a little non-conformity between makes).
6. I'm not quite sure where you're going with the field serviceable. The batteries would be semi-permanently mounted and removed only for replacement. If it uses screws, it should probably use Philips.
7. The brackets preferably should not overhang, but if necessary a half inch or so would be acceptable. There is nothing to the side anyway, so it would only be infringing on the clearance. The washers are trimmed for the frame above.
8. Fasteners are definitely allowed on the bottom, but the should be as smooth as possible. It's certain that the bottom will scrape ground on a regular basis, so nothing should protrude enough to get caught. I don't have a particular maximum, but as little as possible.
9. It's an E-Firestorm RC car. Here is a picture. For chassis measurements, I can give you some basics, but I can't measure the curves and some of the finer details. What I can get I've listed at the end of this post.
10. I suppose I should mention that the curved sides of the batteries have a diameter height of the battery and the curve is a full half circle. The width (1 3/4" inch) is across the full width of the battery. I just realized that my yellow battery is about 1/8" shorter than the green ones. Tomorrow, I'll go take a look at some other batteries of the same style and compare measurements. I'm pretty sure that they're consistent in width and height, but length might vary based on the capacity.
11. For weight the design should probably use aluminum, and be fairly light. I don't have a limit (beyond the somewhat ambiguous "light"), but I'm reaching the maximum load on the frame, so I don't want to add too much more.
Some holes provided on the top of the brackets would be useful for mounting a board. It doesn't really matter where the holes are positioned in the design so long as there is some reason (such as x inches apart...) since I'll be custom making the board anyway. Just a thought. The design needn't be too fancy, as it would just put the rest of the project to shame (aluminum angle hand cut and drilled). Finally, a cost estimate (for the design) would be appreciated before we get too much further. If you don't want to post it, feel free to PM me.
The body dimensions. I found my calipers, so measurements are fairly accurate:
Width where the batteries are: 5.7"
Depth of side walls to floor (on edge parallel to green batteries): 0.28"
Depth of center well (which yellow battery resides): .55"
Width of center well (inside wall to wall): 2.00"
Distance between inside wall and outer wall (inside wall to wall): 1.64"
Wall thickness: .1"
Horizontal distance("projection") of the slope down from the side wall to the lowest point: 1.42"
Post Edited (SRLM) : 4/28/2009 2:16:07 AM GMT
