Serin
Hello,
I'm using a Bstamp B2P to control a relay and a mini SSCII to control a servo.
The 2 devices are connected to the same com port of a Pocket Pc (Ipaq HX4700).
The data sent to the Mini SSCII are in the range : 1 to 255.
So to prevent any interference between the 2 devices, I·can not use·values from 1 to 255 to control the relay.
Actually my problem is that when I send a sequence to control the Mini SSCII (for example chr(255) chr(1) chr(140) )·the relay is actuated.
So I have to find a sequence to send with the Pocket pc that will only actuate the relay.
Example :· I send "ABC" with the Pocket pc and the relais1 routine is run.
(I'm new to Bstamp and I think I don't master the SERIN command [noparse]:)[/noparse] )
Do you have an idea to solve this ?
Thanks for your time.
This is the code I use :
·x VAR Byte
loop:
·· SERIN 7,16468,[noparse][[/noparse]x]
·· DEBUG "--",x,"--"
·· IF x·="ABC" THEN relais1
GOTO loop
relais1:
· HIGH 0
· PAUSE 600
· LOW 0
··GOTO loop
·x VAR Byte
loop:
GOTO loop
relais1:
· HIGH 0
· PAUSE 600
· LOW 0
··GOTO loop
x VAR Byte(3)
SERIN 16,16468,100,timeout,[noparse][[/noparse]STR x\3]
IF x(0)="A" AND x(1)="B" AND x(2)="C" THEN
GOSUB relais1
ENDIF
timeout:
look at the Pbasic help files under SERIN / SEROUT for explanation of the STR formatter
Jeff T.
Dave
Dave Andreae
Parallax Tech Support·
It works fine within a few minutes [noparse]:)[/noparse] !
Thanks a lot for your help.
Mario
x VAR Byte
loop:
·· SERIN 7,16624,[noparse][[/noparse]STR x\3]
·· IF x(0)="A" AND x(1)="B" AND x(2)="C" THEN relais1
GOTO loop
'****** Relais 1 photo
relais1:
· HIGH 0
· HIGH 1
· PAUSE 600
· LOW 0
· PAUSE 200
· LOW 1
· GOTO loop
