Propeller RAM
BADHABIT
I am curious about the RAM and memory structure in the prop. I have seen that there are SD card add ons for it and would like to know how this changes the memory structure of the system.
From what I've read so far the EEPROM and RAM are equal and program size is limited to what the RAM can store and that's it. That has to be untrue bc there would be no need for the SD cards, unless the card holds extra objects and the RAM is for the Top Object File, or something else that hasn't come to mind yet. Or is it just for data collected from external apparatus? (camera or sensors)
Is it possible to use external RAM chips?· If it were then the ? about 16 cogs or more RAM for the P2·would be easily solved.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Not the way you're thinking about it. There is no way to make external memory an extension of the internal memory.
On the other hand, there is a Z80 emulator written for the Prop and used to run CP/M. There's a version of it that uses external memory to store the Z80 program. There's a performance penalty for this, but the emulator runs faster than the original Z80 systems, so it's very usable.
There's another interpreter for a special form of the Prop's instruction set which is called the Large Memory Model (LMM). It's partially interpreted and only a few times slower than the native instruction set. Several people have proposed running an LMM interpreter with the LMM code in an external RAM. Like the Z80 emulator/interpreter, there would be a performance hit for accessing the external RAM, but it may be reasonable for real-world programs, particularly when you can load small pieces of the program into the cog's memory for full speed execution (like small tight loops).
If the code can be cached (and there is a mechanism for doing that), the performance would not be too terrible. As it stands today uncached with a byte-wide memory I'm getting about 800K LMM instructions per second with fairly optimized fetch code and hardware. Hardware optimized for speed can however do little else except execute instructions and communicate via the serial port.
To get a more I/O friendly external design using one Propeller, one must sacrifice fetch speed using address latch mechanisms. Having to constantly switch the pin directions costs at least 8 clock cycles (100ns at 8MHz). Unfortunately the story does not end with that delay since addresses must be also moved and latched. This requires masking and shifting and bit setting, yada yada yada.
Using two+ Propellers for the problem helps, but then you have latency associated with peripherals being attached to the non-code executing propeller. A design where a parallel bus is used for communication between props is possible but limits memory from 2MB to say 1.5MB. I have such a design documented and somewhat in progress ... a hardware prototype with limited features based on the PropRPM board has been finished since February and XMM code running for over a month ... I call it "iiProp" .
I've looked at using 2 Propellers working in tandem to solve the bus interface requirements, but someone smarter than me will have to figure that out. Problem is how do you split up the task? Obviously one Propeller must execute the instructions. So if the other Propeller magically knew the address to set for the executer to fetch, I'd be in business. One could say with 8 bits what relative address to set or with 4 transactions what absolute address to set, but this is really no better than just using memory attached to one propeller.
My latest study is back to focusing on DRAM (specifically SDRAM) like I did last year. This time though, I'll be using some optimizations to reduce access times. DRAM densities and required pin count are too good to ignore. Hopefull I'll get back to the cache business soon so that access speed is less critical. Meanwhile ... so much to do, so little time.
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
it is not really clear what you are trying too do
distributing single method calls would slow down the system. Because you have overhead for all the communication between the props
maybe you write what you want to do IN THE END.
It's ALWAYS the same. As soon as people tell about their REAL project in DETAIL new and elegant soltutions can be found
otherwise you are leading the forum-members into you "three-circles-around from-the-back-through-the-ey-to-the-heart"-direction
which might be much more complicated than other solutions
best regards
Stefan
Rick
Funny you mention that Rick [noparse]:)[/noparse] It's supposed to be a secret though ... shhhh.
I've spent the last couple of days looking at implementing a synchronous design that would be more Propeller friendly than stock SDRAM. I've planned to use an "Access Packet" format to communicate the transaction to a CPLD which will act as a memory controller. I have written a PASM module along that line.
My initial test bed will be the HX512K board, but I intend to have a higher performance, higher density custom platform board.
The problem with the HX512K now is it focuses more on block transfers ... but even that is geologically slow. Of course having the target platform put the data bits in a wierd place that requires at least 4 extra instructions doesn't help ... an old floppy drive cable could fix that [noparse]:)[/noparse] I'm looking at rewriting the CPLD ABEL-HDL code ... which I've actually used before [noparse]:)[/noparse] to support the faster synchronous random access paradigm. Using a CPLD also fixs byte only transactions in a 16 bit bus.
Having someone else code up the CPLD would speed things up. I have to go back and refresh a bit even with ABEL.
My projected numbers are as follows:
Modified HX512K CPLD and standard 8 bit I/O ... Other Propeller pins in Hydra config:
- Write32 ... 700ns .... 1.4MB/s ... 4 bytes
- Read32 ... 1200ns ... 800KB/s ... 4 bytes
- Write8 ... 1000ns ... 1.0MB/s ... 1 byte
- Write8 ... 4600ns ... 2.1MB/s ... 10 bytes
- Read8 ... 1200ns ... 800KB/s ... 1 byte
- Read8 ... 5450ns ... 1.8MB/s ... 10 bytes
Custom 16 bit I/O FAB ... 11 free Propeller pins for TV, KB, Mouse, SDIO, 4MB+ SRAM.(SDRAM times would be different and require different CPLD logic of course):
- Write32 ... 500ns .... 2.0MB/s ... 4 bytes
- Read32 ... 450ns ... 2.2MB/s ... 4 bytes
- Write8 ... 700ns ... 1.4MB/s ... 1 byte
- Write8 ... 2050ns ... 4.8MB/s ... 10 bytes
- Read8 ... 1075ns ... 930KB/s ... 1 byte
- Read8 ... 4900ns ... 2.0MB/s ... 10 bytes
Just for comparison, a 4 byte "copy" from SRAM with HX512K today takes about 9us as far as I can tell.▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
--Steve
