EB-500 not working - Resolved — Parallax Forums
blittledblittled Posts: 697
edited 2009-04-24 03:30 in Robotics
I am planning on buying a Boe-Bot and I already have an EB-500. Right now I have it connected to a super carrier board with a BS2SX. I can establish connection in from the PC to the EB-500. When I try to go from the EB-500 to the PC I get a solid green light and the PC shows I'm connected but the BS2SX is stuck in the WaitForConnection: IF IN5 = 0 THEN WaitForConnection loop.
Does that mean I fried the output on the EB-500? If so is it worth getting one of the remaining Boe-Bots with the EB-500 or just get the EZ Bluetooth module as a replacement since I'll also be using it with a Propeller chip? Thanks!
I just put on the EB-500 on the boe-bot I bought and ran CmdModeHard.bs2 and everything works ok! Thanks Mike for your input.
What electronics need - MORE POWER!!!!!!!
Post Edited (blittled) : 5/13/2009 12:59:42 AM GMT
    You need to attach a schematic of your EB-500 / BS2sx setup and the source code of the program you're using as attachments to your message. It's difficult at best to guess what else you've done or not done and impossible to make any specific suggestions other than to check your wiring and use existing sample programs with appropriate changes to Baud constants for the differences between the BS2sx and the BS2 used in most examples.
