Programming need — Parallax Forums
Programming need
JereJere Posts: 1
edited 2009-04-23 20:22 in Propeller 1
Am fabricating an animated fiberglass sculpture & new to the prop demo board. Have previously used B-Stamp·& am now having difficulty grasping & adapting Spin to fit my requirements. Need to find Spin proficient programmer to lay down initial, adaptable program utilizing switches, motor mount, HB-25 controler, multiple servos, sound & LED's. Anyone willing & able to help?
  • MagIO2MagIO2 Posts: 2,243
    edited 2009-04-23 10:55
    My guess is that anybody here is willing to help if you have concrete questions and it's very likely that you find someone who is able to help you. But I don't think that you will find someone doing a time intensive coaching.
    You should start with the object exchange. For most of the topics you listed there are drivers in the object exchange already.
  • LeonLeon Posts: 7,620
    edited 2009-04-23 12:59
    Just get a Proto board, or build your own, and start by flashing an LED. Work up from that.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-04-23 14:33
    Hi Leon
    His post·makes me believe that he has a demo board. Why should he switch to a proto board? ;o)
    @ Jere
    Do you have a timeline for your project?
  • heaterheater Posts: 3,370
    edited 2009-04-23 15:07
    Jere.
    Just guessing but if you user name is actually your real name you may be Finnish. If you happen to be in Helsinki or near by perhaps we could meet up and look at your project/s.
    If so just drop me a P.M.
    There is nothing wrong with a Prop Demo board. I made my own lookalike Prop Demo board.
    I have been writing a document for the past couple of weeks titled: "From BASIC to SPIN". It is not a great work but it helps to cover the basics for those who have programmed in BASIC and want to learn SPIN. When I am done I will send you a copy if you still want it. It is in Microsoft Word. I do believe it is going to be a long time before I get done(a couple of months?)but if you still want it I will post a copy.
    Toys are microcontroled.
    Robots are microcontroled.
    I am microcontrolled.
