Keyboard / VGA from a 3.3 volt source..
I just built a YBOX2 kit and just realized that it doesn't have a 5 volt source.. Is there any way I can still get them to work with the 3.3 volt source or am I out of luck?
Abysmal
New ICON coming, gotta wait for the INK to heal, now we have colour!
Abysmal
I just looked at my LadyAda version of the YBox2 and it uses an LM1117-3.3 regulator with the tab soldered to the board. I'd use an LM1117-5.0 regulator and glue it, then connect the ground and input pins together (between the two regulators). The pin assignments are different between the two regulators. Consult the datasheet for specifics.
Post Edited (Mike Green) : 4/22/2009 11:18:30 PM GMT
thanks Mike
Gadget Gangster - Share your Electronic Projects - Sign up as a Designer and get a free 4-pack of Project Boards!
if the monitor goes into sleep mode. (newer monitors)
OBC
New to the Propeller?
