controling a RGB Led — Parallax Forums
LEDboyLEDboy Posts: 21
edited 2009-04-22 07:32 in Propeller 1
I need some help I've been playing around with the FullDuplexSerialPlus program and a RGB Led. What I'm trying to do is us the FullDuplexSerialPlus as an input for the duty cycle of the RGB.· I would like·to be able to ajust the brightness 0 -255 of the 3 colors in order to make diffrent colors...can someone point me in the right direction. It cant be as hard as I'm making it. hahaha·
    edited 2009-04-22 06:53
    Hello,
    the FDS+-onject provides a method
      PUB getstr(stringptr)
    with this you could receive a string containing a character "R" , "G", "B" for indicating the channel and a value
    example: "B128"
    and then use the StrToDec-method to change the string "128" into the integernumber 128
    the string has to be ZERO-terminated when using FDS+
    if you use the extended_FDSerial-object (ExFDS) there is a version where strings can be terminated with a carriage return or
    a self defined delimiter
    then in in the obex there is a PWM-object
    Dedicated pwm generator
    with a small demoprogram for that.
    attention in the CON-section of the PWM-demo you have to change the
    CON _clkmode = xtal1 + pll16x
        _xinfreq = 6_000_000             ' CHECK THIS!!! most parallax boards use  _xinfreq = 5_000_000
    best regards
    Stefan
  • MagIO2MagIO2 Posts: 2,243
    On a first glance it looks like "Dedicated pwm generator" is not optimal for driving the LED. Of course for playing with it it's a fast and easy solution. But I'd never use it in a serious case as you have to start 3 COGs, one for each color.
    A COG using both counters would not be enough as well. But I believe for this usecase it would be feasible to do the PWM in software. Doing a 16 bit PWM @ some kHz should be doable.
