Ultra-newbie question - how do I use the USB interface???
Ok,
Have my SX-Key complete with documentation; fell at the first hurdle. All the documents want me to plug into a SERIAL port and select a SERIAL port from the SX-Key configuration menu.
Of course muggins here went for the USB option ... so how do I persuade my SX-Key software (i'm using 3.2.92h) to use the USB interface?
David
David
Shawn Lowe
When all else fails.....procrastinate!
It transpires that on two of my machines (both vista) the default freq setting of 1Mhz does not allow the SX-Key to work - change it to 4MHz and everything seems ok ...
This is a really cool system which I love - but there really is too much unneccesarry 'clunk' in there ...
David
In regards to debugging and trying to single step your program you have to make sure that the SX-Key is the clock source for your project. Any resonators/crystals have to be removed or the debugger will be grayed out. You can usually leave in a resonator in place for programming however.
Robert
