problems sending big numbers via RS232 — Parallax Forums
nomadnomad Posts: 276
edited 2009-04-22 10:19 in Propeller 1
Ref: problems send big numbers via RS232
hallo,
i have a Propeller Professional Development Board aka PPDB
with a RS232-Port.
the communications from a LinuxSystem via RS232 to the board and back is OK.
in the moment i can only send smallNumbers aka <1>
to the board with:
linux send <1>
board receive <49> as ascii (1)
board if input == 49 then make LED ON
board send "5" back to linux
this is ok
The Problem:
i will send a big decimal-Numbers to the Board
bigNumber <12345>
my first idea, is
on the linux system i cut the bigNumber into single bytes aka 12345 = <1><2><3><4><5>
and send this 5 times to the board
the board receive 5 x the single numbers
the code:
Con
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  Rx   = 31
  Tx   = 30
  baud = 9600
OBJ
   ' Ser : "FullDuplexSerial"
   Ser : "Extended_FDSerial"
Var
  byte input0, input1,input2, input3, input4
  byte output
  long inputInt0, inputInt1, inputInt2, inputInt3, inputInt4
  long inputsInt
  byte asciiBase
Pub Main
  dira[noparse][[/noparse]0]~~   ' Pin05 set output leds
  outa[noparse][[/noparse]0]~    ' Pin05 set low
  asciiBase := 48
  Ser.Start(Rx,Tx,0,baud)
  repeat
     input0 := Ser.RxTime(100)  ' byte as ascii
     input1 := Ser.RxTime(100)  ' byte as ascii
     input2 := Ser.RxTime(100)  ' byte as ascii
     input3 := Ser.RxTime(100)  ' byte as ascii
     input4 := Ser.RxTime(100)  ' byte as ascii
     waitcnt(clkfreq / 10 + cnt)
     convertToInt
     if inputsInt == 12345
        !outa[noparse][[/noparse]0]
        Ser.str(string("5"))
PUB convertToInt
   inputInt0 := (input0 - asciiBase) * 100000
   inputInt1 := (input1 - asciiBase) * 1000
   inputInt2 := (input2 - asciiBase) * 100
   inputInt3 := (input3 - asciiBase) * 10
   inputInt4 := input4 - asciiBase
   inputsInt := inputInt0 + inputInt1 + inputInt2 + inputInt3 + inputInt4
is this a correct code?
is this possible?
when i running the whole stuff
- connections ok
- but no led-blinking ???
- and when i send the output aka inputsInt to the linuxSystem
with Serial.dec(inputsInt)
- the linuxSystem receive grumble stuff not <12345>
the second idea is:
on the Extended_FDSerial object gives a functions
x := Serial.rxDec
this functions should be ok, for receive bigNumbers
but, as per the doku " String must end in a carriage return (ASCII 13) <CR>
under linux i can send : "12345\r"
"\r" is the CR
but when experiment with this stuff, nothing is ok
Thanks for help, trick, tipps and hints
regards
nomad
    edited 2009-04-21 13:08
    Hello Nomad,
    for debugging this
    first step: write a small testprogramm than can send a byte as a hexadecimal value
    that the PC receives short strings like "$FF", "$0D", "$30" etc.
    This means send a "$" and then use the .Hex.-method from ExFDS (Extended_FDSerial)
    I HIGHLY recommend testing this FIRST step until it works 101% properly !
    second step: then send your big number from the PC to the propeller
    send BACK - ALL the received bytes as hexadecimal strings "$30" etc.
    to see what you really receive
    If you need more support on this post CONCRETE questions
    best regards
    Stefan
  • nomadnomad Posts: 276
    edited 2009-04-21 15:12
    hi stefan
    excuse me:
    with this spin-programm all stuff running:
    1) linux send a string as "12345\r" // \r is CR
    2) board receive the BigNumber with: inputInt := Ser.rxDec
    3) if inputInt == 12345
    then blueLed ON
    4) send back a) <5> for it's ok
    send back b) Ser.dec(inputInt) // for debuging
    Thanks for your verry good help.
    Regards
    nomad
    the running code:
       serialPropDevBoard11.spin
       dd. 21.04.2009
       input from linux as string == "12345\r"
    Con
      Rx   = 31
      Tx   = 30
      baud   = 9600
    OBJ
    Var
      byte input
      byte output
      long inputInt
    Pub Start
      repeat
         inputInt := Ser.rxDec  ' long bigNumbers
         if input == 12345
            ' or
            Ser.dec(inputInt)
  • simonlsimonl Posts: 866
    edited 2009-04-21 20:46
    @nomad:
    What your Prop' is receiving is the ASCII character (byte) representation of the string 12345. I see (from your original post) that you've tried to convert this to an integer, but I can't immediately see why your conversion's not working. However, I'm in the process of writing a "Guide to Propeller Communications", so I've attached a modified version of one of my tutorial app's that will do what you're after - I hope it helps (and thank you for giving me the opportunity to give something back to this forum!).
    Cheers,
    Simon
    www.norfolkhelicopterclub.com
    You'll always have as many take-offs as landings, the trick is to be sure you can take-off again wink.gif
    BTW: I type as I'm thinking, so please don't take any offence at my writing style smile.gif
    edited 2009-04-21 21:14
    Of course, what I've done is show you how to compare the input against a string, which I think achieves what you're wanting. However; if you're really wanting to convert the input into a numeric value, I'd suggest you look at the "numbers" object.
    To convert the input string (e.g. inputStr) to a numeric value (e.g. inputVal), you would call the "FromStr" method:
    inputVal := Num.FromStr( inputStr, Num#DEC )
    Cheers,
    Simon
    hi Simon,
    Thanks for your Help.
    i am happy that the stuff running...
    cheers
    nomad
