Variable Debouncing Command
I am looking for a command in which I can use to debounce a variable.
I normally use this code when I have a button connected directly to the·prop so that the user has to press and release the button for the command to take place. Otherwise I was having problems with the command happening multiple times (if the users input was to send a serial command, it would send the command several times)
That command works great if I am using an input pin directly on the prop, but how about if I need to do the same thing with a variable? I have a object that scans multiple 74165 shift registers that have buttons connected to them. I have been using a simple waitcnt command until now, but it just doesn't work very well if the user presses buttons in a row.
Basically, the command I am looking for would be 'Wait Until input.display3 := 0. From looking in the manual it appears the WAITPNE and WAITPEQ only work on the direct pins.
Any ideas?
if ina[noparse][[/noparse]21] waitpne(|<21,|<21,0)
if input.display3 waitcnt((10_000_000 + cnt))
Any ideas?
John Abshier
...this code (in C) compares the new and old input values and will only update the old value once they have been different for 10 clock ticks. It also sets a flag (input_changed) to let the rest of the program know that it has a new value to process.
