Urgent: Need your advise
Hi there,
Is there any problem to use normal battery with configuration below for HexCrawler as I'm having problem to have NiMH battery, 7.2V, 3000mA?
1. 4 pcs 1.5V battery (1200mAH) connected in series. So total voltage = 6V, Current= 1200mA.
2. 2 set of 4 pcs 1.5V battery (1200mAH) connected in series where the 2 set are connected in parallel in order to produce same voltage, but with higher current (2400 mAH)
I recommend that you make up your own 7.2V battery pack using 6 NiMH cells in series. You can easily find AA NiMH cells with a capacity of 2300mAh or 2800mAh made by Duracell or other manufacturers and AA battery holders for 2, 3, or 4 cells are commonly available. NiMH cells are rechargable and maintain their output voltage for more of their discharge cycle than alkaline cells.
