Parallax 433 MHz RF Transceiver Package and RFID Problem
I am using the Parallax 433 MHz RF Transceiver Package with the BS2 BOE and cannot get them to talk together.· I am using the code supplied (as I wanted to get something to work before implimenting it with everything else in my code).· What I want to do is create a passcode that·a BOE-Bot give to a gate depending on an RFID tag used by the Bot to open a gate.· The gate will read the Tag and send a message to the bot that will ask for the pass code.· The bot will then send the 4 number passcode back to the gate and if the code is the correct numbers compaired tothe tag used·then the gate will open.· If not then the gate will not open.· All I am getting with the code supplied is that the tx is always sending the message and the receiver never tx back an acknowledgement that I can see.· If anyone can help it would be much appreciative as this is a final project for my schooling.
Tia'Shar Manetheren
Post Edited (Manetheren) : 5/5/2009 7:20:14 PM GMT
Tia'Shar Manetheren
Dave
Dave Andreae
Parallax Tech Support·
Manetheren
You said you were using the example, but then you posted code that was not the example. Did the example code work?
Assuming the example code worked and this code doesn't, there may be a couple of reasons;
1) You have to provide some time between teh synchronisation pulse and sending data, otherwise, it just looks like confused data. You need a pause between;
PULSOUT Tx,1200 'Send sync pulse to radio
and
' Send preample "UUUU!", packet #, string length, string data, crc
SEROUT Tx, RFBaud, [noparse][[/noparse]"UUUU!", packet, strLen, STR string\strLen,
crc.LOWBYTE, crc.HIGHBYTE]
2) As none of the hardware (transmitters, receivers, stamp) has any buffering, you have to get you rtiming perfect to make these things talk. You have to make ABSOLUTELY sure that only one transmitter is talking at a time (much better to get tranceivers that have buffers). I found the best way to do this is to have a master and a slave. The master transmits three times with a pause between each and then listens. The slave listens until it gets a message and then transmits three times. You have to play with the timing, but I had them working at 9600 baud over 100 metres.
Istha.
The robot is going to lose. Not by much. But when the final score is tallied, flesh and blood will beat the damn monster.
Adam Smith
Manetheren
Tia'Shar Manetheren
Post Edited (Manetheren) : 5/5/2009 11:07:00 PM GMT
Tia'Shar Manetheren
