Help in spanish!
Hola a todos!
Necesito ayuda con el propeller y un modulo wifi. la cuestion es que necesito enviar unos par
Hello everyone !
I need some help with a wifi module I have connected to the propeller. It will connect toa servlet server
I tested the following but it did not work:
serialIWi.str(string("http://192.168.51.120:8080/Servidor?id="id"&idO="idO""))
Can anybody help me ?
Now I ask hoottxu:
Could you tell us the following: have you tested your servlet with a browser ? does it work ? sure ?
Is the wifi module connected to the very same network as the pc/server ? can you receive data with the propeller sent by the pc/server ?
@hooktxu:
Podr
El pc y el modulo wifi estan en red, el se4rvlet funciona correctamente y la comunicacion solo se realiza en una direccion, es decir, desde el propeller al pc!
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
Lo que pasa, es que hooktxu deberia explicar mejor su problema (me parece).
You're wrong microcontrolled.
What's happend is that hooktxu should explain better his problem. (I think that).
Regards.
Alberto.
Te aconsejo que intentes escribir en Ingles.
Intenta explicar con m
... and ... what about the wifi module?
a m
Utilizo el modulo iwifi Secure Socket.
