Button Command Input For BS2
ok this is such a new newbie Retarded question.
Building a air shifter kill box for a motorcycle.. consists of
relay swiching on pin 14···· <Actuates Air Shifter>
relay swiching on pin 15···· <Kills Motorcycle For Designated Time>
relays are switched with npn transistors
Input Switch on pin 7
input switch is wired as described in manual
10k resistor and 220ohm...
if i use buttonpush command it only picks it up SOMETIMES or not at all
if i use INPUT un a look it picks it up say once every 30 push's
why is a simple button so hard?
i need a consistant input < It MUST run subs EVERYTIME it is pushed.
PLEASE HELP the warm weather is here and i need this completed for the track....
thank you everyone for even taking the time to laugh at this.
Matt
Matt
Mike2545
This message sent to you on 100% recycled electrons.
even flowing the book and sample code does not work consistantly.
matt
Mike2545
