Write Failure on COM3
I'm using a propeller demo board.
While loading a program to ram that has worked many times before, I now receive a "Write Failure on COM3" error message after "Loading RAM". F7 finds the propeller, F8 shows only 1300 longs used, F9 says it compiles properly. I've swapped cables, turned everything off/on, changed USB ports, all to no avail.
Other programs consistently load properly.
What should I be looking for?
Kurt
Kurt
There was a bug in the 1.1 release relating to write errors.
Propeller Downloads
With my computer in the workshop upload of the same program works fine. But these days I figured out, that this computer also has problems to write an eeprom file which almost has 32k.
I then reinstalled the software on the first computer and it works just fine now.
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
