Just got my Parrallel LCD, but am having power issues!
I just received my Parallel LCD (603-00006) from Parallax and hooked it up to the LCD connector on my ET-BASE P40 basic stamp. I've removed all other connections / sensors etc.
The problem is, I can't seem to provide enough power to run the stamp and the LCD. I just connected two 9v batteries in parallel to the stamp, yet I cannot even ID the stamp from my PC unless I unplug the LCD from it. The onboard regulator on my stamp gets warm quick, despite there not being enough power.
How much current is this LCD supposed to need? I can only find voltage references in the PDF's.
Can anyone please help?
Russ.
Russ.
Mike2545
This message sent to you on 100% recycled electrons.
Vdd & Vss are identical, but the rest of the pins are on opposite sides of the connector. This would explain why the regulator is heating up if it's creating a bad circuit.
I wish I'd known about parallax before I brought this stamp I have, it's an OEM version and I'd rather have paid the money for the parallax original. Hoping I haven't done any damage.
I don't want to mess around with re-soldering my LCD so I suppose I need to find some more 14-pin connectors somewhere and make a converter cable. I'd set aside today to get my LCD running and to understand how to operate it, looks like I won't be doing that now!
Russ.
Hopefully, my experience will prevent someone else with an OEM basic stamp from having the same catastrophe.
Russ.
