XBee Object with Prop
I am trying to use XBee modules with the prop. I want to send data FROM the prop TO a PC. I have the XBee's working BUT...
I have both XBee units set for 57600 baud. I have a GPS that is set for 57600 baud. Works GREAT ! Only using TX/RX signals.
Then I write a program to send "Hello World " via the Xbee but the data is unreliable... I never quite get the complete "Hello World " but just bits and pieces of it...enough to see the XBee's are working (sort of).
Could it be the GPS unit has a hardware uart and the prop is a 'bit banger' ? I have tried it at various speeds (changing the xbee's baud rate accordingly) The lower speeds work better than higher....but not by much.
Anyone have XBee object experience ??
BTW.. Single characters work MOST of the time. It's 'XB.str(string("Hello World "))' that is having trouble.
It turned out to be a faulty row on my breadboard that didn't ALWAYS make good contact. I put a fatter wire in it to make better contact and the problem dissappeared.
Bottom line - sounds like some kind of faulty communication. If your software is sound, then it's gotta be hardware...
BTW, I don't remember if I sent you a message. I got your gyro boards yesterday. I'm going to be playing with them and trying to get the gyro's mounted on them later this week. I should have it working by next friday. [noparse]:)[/noparse]
Time to hit the sack tonight...
Thomas Talbot, MD
Gunpowder, MD, USA
Other wise, it can happen that it starts to stall and give just parts back.
Did you get the pcb's yet by post.
I had send you a complete set of our uav pcb's
1x IMU board
1x MCU board
1x Remote board
Best regards Oliver
Earl
There are 2 things you have to take care of ,
first set with the xbee tool the modules destination address to each other.
Its the address what you find on the sticker on the bottom of the xbee.
2. you need to write the command
+++ ATRW
after any firmware change or update.
or it will stop working after a few mins. that drove me nuts. but no they work great
Works like a charm. You would think the manual would tell you this right up front. All I saw mentioned was a parameter called 'MY'. I could not find it with the X-CTU windows software.
Earl
