Does the propeller actually need and EXTERNAL EEPROM?
Hi guys,
I am a bit puzzled.· I will be building my first board using a prop (have been experimenting with the demo board) and am wondering if I need the external EEPROM.· The data sheet and manual seems to indicate that the chip has its own ROM, yet there are many references that seem to indicate you have to have an external EEPROM if you want the application to start up without having to download the program.
Chris
Chris
This is what the internal ROM is used for: (taken from en.wikipedia.org/wiki/Parallax_Propeller )
ROM extensions
In addition to the Spin interpreter and a bootloader, the built-in ROM provides some data which may be useful for certain sound, video, or mathematical applications:
* a bitmap font is provided, suitable for typical character generation applications (but not customizable);
* a logarithm table (base 2, 2048 entries),
* an antilog table (base 2, 2048 entries),
* and a sine table (16-bit, 2049 entries).
The math extensions are intended to help compensate for the lack of a floating-point unit as well as more primitive missing operations, such as multiplication and division (this is masked in Spin but is a limitation for assembly language routines). The propeller is a 32-bit processor, however, and these tables may not have sufficient accuracy for higher-precision applications.
The internal RAM is volatile and you will loose any program (Asm or Spin programs) .that's loaded once the power is turned off. When you want to keep a program accessible even after the power is turned off you have to store it in the external l EEPROM .
Aka: CosmicBob
The propeller has a main hub RAM that is accessible by any of the cogs and each cog has it's own RAM that it can access via asm code.
Toys are microcontroled.
Robots are microcontroled.
I am microcontrolled.
The boot loader is stored there, so it know what to do when you first power it up.
The reading from serial EEPROM is done through software
and not something the prop would know to do without having internal software stored in ROM.
If you order a few 1000's props, I'm sure Parallax lets you custom make your own Prop ROM.
and the need for an external eeprom could be eliminated.
But you would also loose the ability to make updates on your software, eg no new firmware updates.
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Thanks guys
Chris
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
if space or just not wanting to deal with it I have designed a module with the flash eeprom and crystal on board. size is only 0.1" wider then the dip package.
the advantage of this is that you can remove the memory source and not have to replace it until you reset or turned off the Propeller.
microcontrolled,
the external eeprom for the time being, is based on flash technology. loading off of an external memory chip on bootup is hardly uncommon.
the propeller program runs from RAM. this already allows the removal of the external eeprom until reset or powerup, for whatever reason.
