Bizzaro World PASM code
I'm working on a PASM program and HAD it working... Now it doesn't. The old program is in the eeprom, so when I reset the chip and allow it to load from eeprom, it works fine, so I know it's not a fried chip or hardware issue. I've made some changes to the program, and have no idea what I messed up.
It's acting very strange. When I toggle the CLm pin (pin 0), the CSm (pin 2) toggles and not CLm!
When I wipe out any reference to the TV object, the DIm pin (pin 1) toggles and not CLm.
What the heck is going on?
CON
_CLKMODE = XTAL1 + PLL16X 'Set to ext low-speed crystal, 4x PLL
_XINFREQ = 5_000_000 'Frequency on XIN pin is 5 MHz
Sz = 5
buffSz = 1<<(Sz)
Vref = 5000 'milliVolts
OBJ
TV : "TV_wText_db"
VAR
byte cog
long stack[noparse][[/noparse]100]
byte CPin
byte DPin
byte CSPin
long Sample
long buffer[noparse][[/noparse]buffSz]
PUB Main | Avg, i, index
TV.Start(20)
'Declare Pin assignments
Start(0,1,2)
'Start the PASM program loop for gathering Samples
cog := cognew(@entry,@CPin)
repeat
waitcnt(clkfreq+cnt)
'The basic pin assignment on startup
PUB Start(C, D, CS)
CPin := C
DPin := D
CSPin := CS
DAT
org 0
entry mov dataptrs, par
rdlong dcount,dataptrs
shl CLm,dcount 'mask for Clock pin
add dataptrs,#4
shl DIm,dcount 'mask for Data pin
add dataptrs,#4
shl CSm,dcount 'mask for Chip Select pin
add dataptrs, #4
or dira, CLm 'make Clock an output
or dira, CSm 'make Chip Select an output
andn dira, DIm 'make DataIn an input
:mainloop
or outa, CLm 'Set CS High
nop
andn outa, CLm 'Transition CS low to start conversion...
jmp #:mainloop
CLm long 1 'bit mask for clock pin
DIm long 1 'bit mask for data from adc pin
CSm long 1 'bit mask for cs pin
val long 1
temp long 1
dataptrs res 1 'hub start address for data
dataptr res 1 'current address for data
dcount res 1 'bit count, also temp during startup
FIT 496
are reading them in assembly (rdlong) as though they were longs.
Also, with a "byte" declaration they are probably not long-aligned, so you're
probably not even reading where you think you are.
Either make all three longs, or use rdbyte and increment the address by one,
not four.
I have a feeling that will fix it. Thanks rokicki.
