Can a COG access another COG's DIR?
I built a program that would display a 1 if pin 0 was an input, and 0 if it was an output. I tried it, it worked fine while the DIRA command was in the same cog, but when tried with a different COG changing the DIR, it wouldn't work. So, I referred to the trusty Propeller Manual. In it it said that each COG keeps it's own DIR register, which is OR-ed (or OR'd?) with the other COGs. Is there any way that·I can, from one COG, copy the DIR register from another COG at any given time?
Basic Stamp,···· Propeller,·· · SX,·· FUN!
START:·
>Proccessing Data. . . .··
>Task Complete. . .·.
>Saving Data. . . .
>Entering SLEEP Mode. . . .
>Signing OFF
START:·
>Saving Data. . . .
>Signing OFF
START:·
>Saving Data. . . .
>Signing OFF
Usually you should know which COG uses which PINs. That's why each and every object in the ObEx should define a constant like basepin or constants where you can configure the pin numbers. And lesson one for propeller programmers should be: check the setup of each object.
And NO, there is no other way. The COG RAM is only readable by the COG itself.
START:·
>Saving Data. . . .
>Signing OFF
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
Also, you can wire or yourself by using a pullup (10K) and just driving the dir register on/off with the outa =1.
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
· Search the Propeller forums (via Google)
It's a stupid idea, really, but provides the desired info, assuming each pin eventually sees a "high".
