Stepper Motor Identification
This may not be the right place to ask this, but I thought since I will be using my motors with a BS2 stamp I would give it a shot.
I rcently purchased a bunch of stepper motors that are both bi and unipolar. I have no idea which wire goes where. Is there a way to test the wires to determine which ones are power and ground? If I can figure that out, I will hopefully be able to determine which ones are for step and·which·are for direction. Thanks for your help.
- Stephen
Once you know which wire (s) is(are) the common, you can find the order of the phases with a stepper controller or a battery. If you can connect it to a controller and provide direction and step signals continuously, the motor will either turn, or shake. If it shakes, swap one of the A wires with one of the B wires. If it turns in the wrong direction, swap the two A wires. If your wires are labeled A, B, C, D rather than A+, A-, B+, B-, that should read: If the motor steps back and forth, swap B & C. If it runs backwards, swap A & B. {Thanks to Steve Baldmin or TLA Microsystems Ltd, Auckland, New Zealand}
- Stephen
