driving LED from 115vac — Parallax Forums
Erik FriesenErik Friesen Posts: 1,071
edited 2009-04-17 20:31 in General Discussion
Any opinions on the best way to do an indicator light powered from 115vac?
options -
series resistor to bipolar led
series resistor to diode to led
small capactior to resistor to bipolar or diode-led
    edited 2009-04-17 14:15
  • BeanBean Posts: 8,129
    edited 2009-04-17 15:16
    Erik,
    Just aware that the link PJ gave is using 230V mains not 115V mains. So you'll have to adjust the value accordingly.
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
  • Erik FriesenErik Friesen Posts: 1,071
    edited 2009-04-17 15:34
    I am looking for minimal components here. Can that be done with one diode only?
  • LeonLeon Posts: 7,620
    edited 2009-04-17 16:05
    You need something else to reduce the voltage!
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    edited 2009-04-17 16:35
    As the article in the link states, you can ditch the bridge rectifier circuit and add a reverse protection diode (or a second, reverse-connected LED) across the LED instead. This protects the LED from high reverse voltages. You still need the series components for current limiting, though. A milliamp-range fuse is necessary, too, in case one of the components fails short.
  • Mike2545Mike2545 Posts: 433
    This will work...It's been drawn for an opto-isolator but will work well for an LED smile.gif
    Or use a neon with resistor.
    Mike2545
    This message sent to you on 100% recycled electrons.
    Post Edited (Mike2545) : 4/17/2009 4:40:45 PM GMT
    edited 2009-04-17 16:48
    @ leon. I meant using a resistor and or cap first. I don't wish to use a bunch of components as I have 7 - 115v out relays that I want to indicate.
    edited 2009-04-17 16:53
    @ mike - is that millifarads or microfarads?
    edited 2009-04-17 17:37
    Eric, its microfarad 160 Vac found here www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMvOcEq4GH1AAjFenWuujJ69ZmewO7woKe4%3d
    Mike2545
    Thanks for the ideas. I think a mb4s from fairchild will do the trick.
