crc16 — Parallax Forums
crc16
Earl FosterEarl Foster Posts: 185
edited 2009-04-18 11:46 in Propeller 1
Has anybody written code for crc16 (crc-ccitt)·and·is willing to share?
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
  • David BDavid B Posts: 593
    edited 2009-04-16 16:42
    I wrote this a long time ago to calculate the CRC for a sector of data read from a floppy disk, where a global byte array sectorbuffer[noparse]/noparse holds 0-511 bytes followed by two CRC values. It is hardcoded to the specific form of CCITT CRC used by floppies.
    The routine calculates the CRC on all data plus the CRC values and returns zero if the data is OK, non-zero on error. I haven't run it for a long time but I believe it was working properly.
    PUB doCRC | byteloop, bitloop, crc_value, ccitt, xorflag, mask, data_value
      crc_value := 14192
      ccitt := 4129
      repeat byteloop from 0 to 513
        data_value := sectorbuffer[noparse][[/noparse]byteloop]
        mask := 128
        repeat bitloop from 0 to 7
          xorflag := crc_value & 32768
          crc_value <<= 1
          if data_value & mask <> 0
            crc_value++
          mask >>= 1
          if xorflag <> 0
            crc_value ^= ccitt
        crc_value &= 65535
      return crc_value
  • jazzedjazzed Posts: 11,803
    edited 2009-04-16 18:18
    Table driven version if you have plenty of memory to spare [noparse]:)[/noparse]
    * CRC16 - Uses CCITT polynomial
    * Copyright (c) 2009, John Steven Denson
    * See MIT license agreement terms at end of file
    { add comment tick before first char of this line for demo.
    CON
       _clkmode = xtal1 + pll16x
       _xinfreq = 5_000_000
    var
       'byte value[noparse][[/noparse]3]
       long r
    obj
       debug: "fullduplexserial"
    pub main | i
       Debug.start(31, 30, 0, 115200)      'Start the debug terminal
       waitcnt(clkfreq*2+cnt)
       init(CCITT_POLY)
       r := get(@value,  strsize(@value), 0)
       debug.str(string($d,$d,"CCITT CRC16 INIT $0000 -> $"))
       debug.hex(r, 4)
       r := get(@value,  strsize(@value), CRC_INIT)
       debug.str(string($d,"CCITT CRC16 INIT $FFFF -> $"))
       debug.hex(r, 4)
       r := get(@value,  strsize(@value), $1d0f)
       debug.str(string($d,"CCITT CRC16 INIT $1D0F -> $"))
       debug.hex(r, 4)
    dat
      value byte "000501",0
    CON
      start with -1 to detect blank array
      mycrc := crc.get(dptr, bc#BIOS_DBASE_SIZE-2,CRC_INIT)
      CRC_INIT = $FFFF
      CCITT_POLY = $1021
    DAT
      long
      crc_table word 0 [noparse][[/noparse]16*16]
    PUB init(poly) | ii, jj, mcrc, c
      initialize table using polynomial
      @param poly - bitstream representing polynomial ex: 0x8404
      repeat ii from 0 to 255
        mcrc~
        c := (ii << 8) & CRC_INIT
        repeat jj from 0 to 7
          if ( (mcrc ^ c) & $8000 )
            mcrc := (mcrc << 1) ^ poly
          else
            mcrc <<= 1
          c <<= 1
          mcrc &= CRC_INIT
        word[noparse][[/noparse]@crc_table+ii<<1] := mcrc
    PUB get(msg, len, val) | ii
      Get CRC for len msg with intial ival
      @param msg - byte array message
      @param len - number of bytes in msg array
      @param val - initial crc value ... normally $FFFF
      @returns CCITT CRC16
      repeat ii from 0 to len-1
        val := CRC(val, byte[noparse][[/noparse]msg+ii])
      val &= CRC_INIT
      return val
    PUB hash(key, mlen, mmask) | len
      Get a CRC16 based hash of key of maximum length mlen key using mmask.
      This function will not create a perfect hash for all data.
      Other algorithms must be used in addition to guarantee uniqueness for keys.
      @param key - key byte array string
      @param mlen - maximum number of bytes in msg array
      @param mmask - mask used to defin 2^N hash table size
      @returns CCITT CRC16 based hash
      len := strsize(key)
      if len => mlen  ' just calculate over the first VLEN bytes
        len := mlen
      result := get(key, len, CRC_INIT)
      result &= mmask
    PRI CRC(crcval, ch) | ii
      ii := (crcval >> 8) ^ ch
      result := ((crcval << 8) ^ word[noparse][[/noparse]@crc_table + ii<<1]) & CRC_INIT
                                 TERMS OF USE: MIT License
    Permission is hereby granted, free of charge, to any person obtaining a copy
    of this software and associated documentation files (the "Software"), to deal
    in the Software without restriction, including without limitation the rights to
    use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
    of the Software, and to permit persons to whom the Software is furnished to do
    so, subject to the following conditions:
    The above copyright notice and this permission notice shall be included in all
    copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
    IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
    FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
    AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
    LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
    OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
    SOFTWARE.
    Corrected version. Use your own polynomial for init if you like. Init must happen before CRC16 calculation. A demo is enclosed in { } above.
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    Post Edited (jazzed) : 4/17/2009 10:32:12 PM GMT
  • Earl FosterEarl Foster Posts: 185
    edited 2009-04-16 19:40
    Thanks guys. I will have to study both of these for a little while. Since I need to use XModem I assume I change the initial value to $0000
    WWW.HAPB.NET
    edited 2009-04-17 14:11
    Steve,
    I think I am using your program incorrectly.· I am assiging "get(...)" to a variable and I am getting the incorrect CRC.· I modified the top to do a simple test and the r = $E415 when it should equal $2348 according to a·online CRC calculator. (http://www.lammertbies.nl/comm/info/crc-calculation.html?crc=000501&method=hex)
    CON
      mycrc := crc.get(dptr, 1024, CRC_INIT)
       CRC_INIT = $FFFF
    var
       long r
    obj
    pub main | i
       waitcnt(clkfreq+cnt)
       value[noparse][[/noparse]0] := $00
       value[noparse][[/noparse]1] := $05
       value[noparse][[/noparse]2] := $01
       Debug.start(31, 30, 0, 9600)      'Start the debug terminal
       r := get(value, 3, $FFFF)
       debug.hex(r, 4)
    DAT
       Rest of the code is exactly what you provided.
    Can you set me straight?
    WWW.HAPB.NET
    edited 2009-04-17 17:12
    Hmmm ... looking at it.
    One thing to note is you would need to pass the value by reference as in: r := get(@value, 3, $ffff) .... still get the wrong value though.
    I'll post a corrected and more flexible version sometime today.
    --Steve
    edited 2009-04-17 19:58
    David,
    I have tried playing with the code you provided and I am unable to get the correct CRC based on CRC site is use (http://www.lammertbies.nl/comm/info/crc-calculation.html?crc=000501&method=hex).· I am probably using it incorrectly.· I have made some assumptions and adjusted the code:
    ·- adjust byteloop to fit data size
    ·- crc_value is the initial value
    ·- ccitt is the poly
    CON
    var
       long r
    obj
    pub main | i
       r := doCRC
       debug.hex(r, 4)
      crc_value := $FFFF
      ccitt := $1021
      repeat byteloop from 0 to 2
        data_value := value[noparse][[/noparse]byteloop]
        mask := 128
          crc_value <<= 1
            crc_value++
          mask >>= 1
          if xorflag <> 0
            crc_value ^= ccitt
        crc_value &= 65535
      return crc_value
    Can you provide guidance?
    WWW.HAPB.NET
    edited 2009-04-17 22:27
    My post has been updated. It contains a demo that matches the results on the web site. I had been using a special polynomial and interpretation for a project ... pardon my mess.
    --Steve
    edited 2009-04-17 22:52
    I'll try your test when I get a chance. I'm at work now, and don't have access to a propeller test platform, and my wife has made plans to go out for dinner tonight, so I probably won't get to it until this weekend sometime.
    When I was learning how to get the floppy CRC to work, I found lots of variations in how CRCs are calculated. Some routines initialize the crc_value to 0, some to $FFFF, some to some other number. Some implementations invert results at some stage, some don't. And there are lots of different polynomials in use.
    Floppy disks seem to initialize the crc_value to 14197 for the crc on the floppy header and to 14192 for the crc that follows the 512 bytes of data, but I've never found any documentation explaining why this is the case.
    I'll hack around with your example and see if I can get it to work, and post what I find in a day or so.
    David
    edited 2009-04-17 23:33
    Steve,
    This is great! You should post it in the obex since there has not been a CRC16 routine until now. Thanks
    WWW.HAPB.NET
  • RaymanRayman Posts: 16,235
    I've posted a couple versions of a YMODEM (better than XMODEM) utility for the Prop that works with, e.g., hyperterminal.
    It, of course, includes the crc16 code....
