how to out put the data form debug terminal of bs2
As title
i have collected some data in the debug terminal , but i don't know how to output the data to the computer or save as another readable format on computer(say, .txt) inorder the let others to get the data.
i would like to ask if there are any path for me to do so.
http://www.parallax.com/tabid/441/Default.aspx
Dave
Dave Andreae
Parallax Tech Support·
However, I encounter another problem when trying to use PLX-DAQ.
When using the Basic Stamp Window Editor and run my program, PLX-DAQ fails to be connected.
On the other hand, if PLX-DAQ is connected first, the program cannot be runned since the Basic Stamp Window Editor cannot find the stamp through the port.
I would like to ask what should be done in order to solve the problem. Thanks.
- Stephen
Or put it in another way (I am not sure whether my idea is correct or not ^_^')
Is there any way I can make stamp to run without using the basic stamp window editor programme?
If the stamp run by itself without using the window editor, then can PLX-DAQ obtain data in this way?
- Stephen
