Copper Pour on PCB Tips
I've designed a double-sided Prop-based board (dip version) and have everything laid out and routed. I copper poured ground to the top layer and am wondering if I should put a copper pour on the bottom layer.
If I do put a copper pour on the bottom side, what NET should I tie it to? I have an unregulated +11.1 V, and regulated +5V and +3.3V power NETs. Should I make the bottom side GND, +3.3V (powers prop and eeprom, sd card, two other ICs), or +5V (powers four ICs)? Or should I not even bother with copper pouring the bottom side? The fasting switching speeds are the Prop itself, serial communications of at most 115,200 baud rate, and SPI on the sd card... also, I have a Bluetooth module breakout board that sits on the board. I used through-hole parts for everything... (I suspect that ground planes on both sides might exhibit unwanted capacitance and a slight charge buildup if I'm not careful).
My protoboard with wires everywhere (even for power) doesn't seem to exhibit too many problems, so I'm wondering If I'm just over-doing it... but just for future reference I want to know what the best practices are for something like this.
Thanks.
dwelve
Thanks.
dwelve
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
Thanks again.
dwelve
Talking about grounds though I usually make sure that I place a 2-pin jumper (0.1" pin strip) as a test ground somewhere accessible on the pcb.
*Peter*
*Peter*
www.fd.com.my
www.mercedes.com.my
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
