Autonomous GPS Robot — Parallax Forums
mitesh22mitesh22 Posts: 12
edited 2009-05-12 01:35 in Accessories
Hey Guys
This is Mitesh and Sanjeev from Chicago,
We are building up an autonomous GPS robot, and need help from all of you experts.
So far we have got all the hardware, as far as the designing is concern, the ultrasonic sensor, and servos have been designed.
We will be posting the codes for·that and also looking to get help for the GPS coding.
Thank You
  • SRLMSRLM Posts: 5,045
    edited 2009-04-15 20:23
    Any code that you might need is dependent on the hardware. Give some specifics, and you may get some useful answers. Without details (including design goals), we can't really give much help.
  • mitesh22mitesh22 Posts: 12
    edited 2009-04-16 02:10
    sure, we will be back to you from our school with the schmatic and goalplus the design too.
    Basically right now, i was trying to understand that code that was developed by the parallax in order to get the values of Long, Latti. from GPS, found that code at parallax website.
    Now I wanted to create a final point for our Robot where it should br lead by the GPS.
    I might have to come up with a loop that compares the Data received by the GPS module and also the Data of our final set point.
    I will be posting the source code for that tomorrow.
    Thank you for your courtesy though.
    Looking forward to talk to you!
    Mitesh
  • Tom CTom C Posts: 461
    edited 2009-04-16 11:32
    mitesh22,
    Attached is an example of a GPS guided car that uses the Parallax Hitachi compass and the Parallax GPS.
    It will provide you with an example of the challenges that you are facing.
    TCIII
    If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
    edited 2009-04-20 17:24
    Hey Thanks a ton for your feed back
    Here are the two codes that we have so far, one is for an ultrasonic sensor that senses an object within 2 feet.
    and the other one is as followed:
    [noparse][[/noparse] I/O Definitions ]
    Sio PIN 15 ' connects to GPS Module SIO pin
    ' GPS Module Commands
    GetInfo CON $00
    GetValid CON $01
    GetSats CON $02
    GetTime CON $03
    GetDate CON $04
    GetLat CON $05
    GetLong CON $06
    GetAlt CON $07
    GetSpeed CON $08
    GetHead CON $09
    [noparse][[/noparse] Variables ]
    char VAR Byte
    workVal VAR Word ' for numeric conversions
    eeAddr VAR workVal ' pointer to EE data
    ver_hw VAR Byte
    ver_fw VAR Byte
    valid VAR Byte ' signal valid? 0 = not valid, 1 = valid
    sats VAR Byte ' number of satellites used in positioning calculations
    degrees VAR Byte ' latitude/longitude degrees
    minutes VAR Byte ' latitude/longitude minutes
    minutesD VAR Word ' latitude/longitude decimal minutes
    dir VAR Byte ' direction (latitude: 0 = N, 1 = S, longitude: 0 = E, 1 = W)
    speed VAR Word ' speed in 0.1 knots
    des_deg VAR Word
    des_min VAR Word
    des_mind VAR Word
    COUNTER VAR WORD
    [noparse][[/noparse] EEPROM Data ]
    NotValid DATA "No", 0
    IsValid DATA "Yes", 0
    [noparse][[/noparse] Initialization ]
    Initialize:
    PAUSE 250 ' let DEBUG open
    DEBUG CLS ' clear the screen
    DEBUG "Parallax GPS Receiver Module Test Application", CR,
    Draw_Data_Labels:
    DEBUG MoveTo, 0, 3, " Hardware Version: "
    DEBUG MoveTo, 0, 4, " Firmware Version: "
    DEBUG MoveTo, 0, 6, " Signal Valid: "
    DEBUG MoveTo, 0, 7, " Acquired Satellites: "
    DEBUG MoveTo, 0, 12, " Latitude: "
    DEBUG MoveTo, 0, 13, " Longitude: "
    DEBUG MoveTo, 0, 15, " Speed: "
    DEBUG MoveTo, 0, 16, " Direction of Travel: "
    [noparse][[/noparse] Program Code ]
    Main:
    GOSUB Get_Info
    GOSUB Get_Valid
    GOSUB Get_Sats
    GOSUB Get_Lat
    GOSUB Get_Long
    GOSUB Get_Speed
    GOSUB Get_Head
    des_deg = xxxxx
    des_min = yyyyy
    des_mind = zzzzz
    IF(des_mind > minutesD)
    FOR COUNTER = 1 TO 100
    PULSOUT LeftServo, 850 ' Left Servo Left Pulse Value
    PULSOUT RightServo, 850 ' Right Servo Left Pulse Value
    PAUSE 20
    NEXT
    PULSOUT RightServo, 650 ' Right Servo Left Pulse Value
    PAUSE 20
    NEXT
    ELSE IF(des_mind < minutesD)
    PULSOUT LeftServo, 650 ' Left Servo Left Pulse Value
    PAUSE 20
    NEXT
    PAUSE 20
    NEXT
    The rest of the code is same as what they have posted at their homesite.
    But do you have any suggestions on this code:
    If my car starts a certain point, it is going to read three variables for GPS.
    1. degree 2. minutes and 3. fractional minutes.
    Now we have readings that every 7.5 feet the fractional minute changes by 0.1
    And since we are testing it in the parking lot(relatively small area), as the robot moves a bit, the only reading that changes is fractional minutes.
    In the code, I tried to compare the final reading (taken manually) with the one that we get from the GPS.
    Direct us in the logic or coding from here onwards
    Thank you
    Looking forward to see some feed back
    Mitesh
    edited 2009-04-20 17:27
    here is the code for the ultrasonic sensor friends
    Smart Sensors and Applications - PingMeasureCmAndIn.bs2
    ' Measure distance with Ping))) sensor and display in both in & cm
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    RightServo PIN 12 ' Right Servo
    LeftServo PIN 13 ' Left Servo
    Ping PIN 15 ' PING))) Sensor
    pulseCount VAR Byte ' Used For Measuring Turns
    ' Conversion constants for room temperature measurements.
    CmConstant CON 2260
    InConstant CON 890
    cmDistance VAR Word
    inDistance VAR Word
    time VAR Word
    task VAR Nib ' Current Task
    DO
    PULSOUT 11, 5
    PULSIN 11, 1, time
    inDistance = inConstant ** time
    DEBUG HOME, "The distance is ", DEC2 inDistance, " in"
    IF (inDistance < 18) THEN ' Wait For 10 Servo Pulses
    GOSUB Turn_Right
    PAUSE 200
    GOSUB Go_Forward
    PAUSE 200
    GOSUB Turn_Left
    PAUSE 200
    GOSUB Go_Forward
    PAUSE 200
    GOSUB Turn_Left
    PAUSE 200
    GOSUB Go_Forward
    PAUSE 200
    GOSUB Turn_Right
    PAUSE 200
    GOSUB Go_Forward
    ELSE
    GOSUB Go_Forward
    ENDIF
    'PAUSE 1
    LOOP
    Turn_Left: ' Left Turn, About 45 Degrees
    FOR pulseCount = 0 TO 40 ' Number Of Pulses To Turn
    PAUSE 20 ' Refresh Delay
    NEXT
    RETURN
    Turn_Right: ' Right Turn, About 45 Degrees
    PULSOUT LeftServo, 850 ' Left Servo Right Pulse Value
    PULSOUT RightServo, 850 ' Right Servo Right Pulse Value
    PAUSE 20
    NEXT ' Refresh Delay
    RETURN
    Go_Forward: ' Right Turn, About 45 Degrees
    FOR pulseCount = 0 TO 200 ' Number Of Pulses To Turn
    PULSOUT RightServo, 650 ' Right Servo Right Pulse Value
    NEXT
    RETURN
    Go_Backward: ' Right Turn, About 45 Degrees
    FOR pulseCount = 0 TO 100 ' Number Of Pulses To Turn
    PULSOUT LeftServo, 650 ' Left Servo Right Pulse Value
    NEXT
    RETURN
  • Steve LindengSteve Lindeng Posts: 6
    edited 2009-05-05 21:34
    Gentlemen:
    One quick word of caution:
    GPS speed and heading are only good while the GPS is in motion; when stopped, the GPS cannot calculate the heading as the heading is internally calculated from successive lat/long data. IF you have the bandwidth, adding a compass (such as the Hitachi HM55B) will give a rough heading regardless of motion.
    As for your testing, in a small area such as a parking lot, fractional minutes is fine. Just remember, GPS accuracy is limited to +/- 1 meter (best case), so your error in position may be equal to your movement unless you have 3 satellites or better. You may have to add a test for that and presume dead-reckoning at times. If you have the ability, what I would do would be to have the code wait until Get_Stats returns 3 (or higher), then sprint at least 3 meters (10 feet) to get an accurate relative heading. Store this heading and use it as a reference (increment heading for so many pulses of Left/Right servo to do a dead-reckoning). After every 10 feet or so, find new heading from GPS and compare to expected value. This would a rough substitute for a compass in a pinch.
    Good Luck.
    edited 2009-05-12 01:01
    My professor has also come up with the same suggestion of using a compass.
    But here is the thing, I am not more concern about the direction, but I have to create a final point of that path which has set manually in the program by me, and then the other point is the one which uses the data of the GPS.
    I am sure you are understanding me.
    Here look at the attachment, and give me some suggestion, do I still use the compass?
    bmp
    960K
    GPS.bmp 960.1K
    If you want to do navigation from one point to another, you need a compass or some other reliable method of determining heading.
