I need help with a old BS1!
A friend give me a old BS1, this works, well there is some program on PIC16C56 and LEDs stay doing a Christmas here...
But BS1, come with a old BD25 cable, and I dont have any PC with a DB25 port, the best I have is a DB9 in a old PC... DB25 from BS1 uses pins 2,11 and 25 ... well I cant use a adapter ...
Exists any mode to write to BS1, using DB9 port?
www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/44/Default.aspx?txtSearch=bs1+serial+adapter
www.parallax.com/tabid/391/Default.aspx
I don't believe the current software even supports the parallel port programming process for the BS1, just this serial programming process.
I go try to make my own cable...
EDIT
This worked for me! thanks!
Post Edited (Anunakin) : 4/22/2009 2:12:05 PM GMT
