BS2 resetting
Hello,
·I'm using a BS2 "Board of Education" for my project. When I send a HIGH command to P14 the LED lights but flashes or resets about every two seconds. Why doesn't the LED just stay on?
John
John
Please post your schematic and a listing of your code using the Attachment Manager.
························ Craig Eid
··········· Triad Research and Development
Electical Engineering Design and Consulting Services
··················· www.TriadRD.com
Mike2545
This message sent to you on 100% recycled electrons.
The BS2 outputs 13 & 14 drive the LED's thru a 470 Ohm resistor. In the future I'll use the BS2 output to drive a TIP which will drive the relays.
Here's the code:
'What's a Microcontroller - LedOnOff.bs2
'Turn LED/Relays on with timed delay then hold them in on state till power is switched off.
' {$STAMP BS2}
' {$PBASIC 2.5}
DEBUG "Delayed turn on of two relays!"
DEBUG "Wait 1/2 second to turn on R1"
PAUSE 500
DEBUG "Turn on R1"
HIGH 14
DEBUG "R1 is on"
DEBUG "Wait 5 Seconds to turn on R2"
PAUSE 5000
DEBUG "Turn on R2"
HIGH 13
END
Thanks for your help,
John
I tried switching from a 9V to a 5V power supply. I'm using the "brick" type of power supply. No help...
John
Does the second LED, attached to I/O pin 13, also flash? The 2 LED's should draw approximately 5mA each with·a 470 ohm resistor so you shouldn't be exceeding the BOE current limit. I suspect that you are not supplying sufficient current to the LED's. Try adding a second 470 resistor in parallel to the 470 resistor·attached·to I/O pin 14 and post your results.
Yes, the LED from I/O pin 13 also flashes. No help with the 470 ohm in parallel. Both LED's flash about every 2 seconds but not until the program runs out. The program appears to be running correctly. If I disconnect the LED from pin 13 the pin 14 LED still flashes about every 2 seconds. Could this be the WDT timing out or resetting.
John
- Stephen
You are correct, the STOP command did the trick.
Thanks everyone for you help!
John
