integration of optocoupled relays
I'm looking for suitable hardware such as optocoupled relays that can be used to switch higher current devices, but seem to have problems with voltage dropping at the javelin output. Currently using LAA110 (Clare) 8 pin dip. Can anyone suggest a suitable device and/or circuit?
(5V-1.3V)/10mA = 370 ohm.
JavPin o---[noparse][[/noparse]370ohm]
|>|----GND
JavPin o---|<|
[noparse][[/noparse]370ohm]----VDD
should allow you to switch.
At 10mA, a Javelin I/O pin should not have any voltage dropping.
Note that each I/O pin can deliver 25mA, but per group of 8 pins
(portA and portB) the total is limited to 50mA.
And best to switch the I/O to GND so the pin sinks current
rather than sources current.
regards peter
